Calculating Distance and Direction Between Two Teams in a Remote Area Using GPS
Two geological field teams are located in a remote area, with specific distances and angles provided via GPS. The first team is 38 km at 19° north of west, while the second team is 29 km at 35° east of north. The calculations for the distance and direction between the teams involve vector components, but the initial attempt yielded incorrect results. The correct approach requires using vector subtraction rather than addition to find the distance and direction. The final answers should be approximately 53.8 km and 12.2° from due east.
jehan4141
Two geological field teams are working in a remote area. A global positioning system (GPS) tracker at their base camp shows the location of the first team as 38 km away, 19° north of west, and the second team as 29 km away, 35° east of north. When the first team uses its GPS to check the position of the second team, what does the GPS give for the distance between the teams and direction,θ, measured from due east?
Fx = Fax + Fbx
Fy = Fay + Fby
Resultant vector = sqrt[ (Fx2 + Fy2 ]
Θ = tan-1 (Fy/Fx)
Fx = -38cos19 + 29cos55 = -19.29598922
Fy = 38sin19 + 29sin55 = 36.12699915
Resultant vector = sqrt [ (-19.29598922)2 + (36.12699915)2]
Resultant vector = 40.95723706 meters
Θ = tan-1(36.12699915/-19.29598922)
Θ = 61.89263517 degrees N of W
Those are my answers but apparently they are wrong. The provided answers are 53.8 km, 12.2 ° from east. Where am I going wrong? Thank you in advance :)
You determined A + B. I think you want B with respect to A. Draw a diagram of what is going on and you may see the solution.
Isn't A+B the distance between A and B?
I drew a diagram from the very beginning and still don't see my error.
No. It is a vector sum. I think you want a vector difference.
