Calculating Man's Northward Distance Traveled with Vector Components
To calculate the northward distance traveled by a man running at 5 m/s at an angle of 25 degrees north of east for 10 minutes, vector components should be used. The northward component of the velocity can be determined using the formula 5(sin 25). After converting time from minutes to seconds, the distance can be calculated using the equation distance = velocity x time. Alternatively, the total displacement can be calculated and then broken down into its components to find the northward distance. Both methods will yield the same result for the distance traveled north.
ch2kb0x
Man runs with velocity = 5m/s @ 25 degrees north of east for 10 minutes.
How far to the north of his starting position does he end up?
I know this has got to be the easiest problem to solve but I am not getting it. this is what I did.
It asked for how far to the north, so I assumed they were looking for a final position. I used vector components (5cos25)i + 5(sin25)j, but I don't know how to solve for the distance x. I know there's a formula v = x / t but that didnt help.
Vector components is the way to go. They only ask for the distance traveled North, so use the component of the velocity along the y-axis (North) and from that magnitude (speed), you can use your Speed = distance/time equation.
i.e. x = vt
(remember to convert time to seconds).
OR
You could work out his displacement, using Velocity = displacement/time, i.e. Displacement = velocity x time and then break the displacement vector down into components.
Both should give you the same answer.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
