Vector magnitude and displacement
To determine the total displacement of a car driven in multiple directions, the contributions from each segment must be calculated, including the final leg of 28 km at 25° east of north. The east and north components of this leg can be found using trigonometric functions, specifically x = 28cos(25°) and y = 28sin(25°). After calculating the components, they should be summed with the previous distances driven east (48 km) and north (25 km). The overall displacement can then be found using the Pythagorean theorem on the total east and north components. Understanding the vector components is crucial for accurate displacement calculations.
jpd5184
A car is driven east for a distance of 48 km, then north for 25 km, and then in a direction 25° east of north for 28 km. Draw the vector diagram and determine the total displacement of the car from its starting point.
whats the magnitude and direction(counterclockwise from east)
A^2=Ax^2 + Ay^2
i plugged in 48km for Ax and 25km for Ax and got 82.103km for my answer
you seem to be missing the contributions of the 28 km. Draw the diagram and attach it.
i noticed that the 28km was left out, i drew it on my picture but I am not sure what forumula to use to utilize it.
Are you able to break down the 28 km into its east and north components? If you can do that, then add all the east components together, and then ... can you do it now?
do you mean like:
x= 28cos25
y= 28cos65
yes, except I think your angles should be interchanged. Then to get the overall displacement you have an x component of 48+28sin25 and a y component of ... Then use pythagoras on the two overall components. In future, try to not think of 'plugging into a formula' without thinking what it means.
