What is the new position vector if the reference point is changed to (0,4)?
  • Thread starter Thread starter tmgrich
    Torque Vector
The discussion centers on calculating the torque of a particle when changing the reference point from the origin to (0, 4). The position vector of the particle is given as r = (i + 3j) m, and the force acting on it is F = (5i + 6j) N. Torque is defined as the cross product of the position vector and the force vector. When changing the reference point, the new position vector must be recalculated relative to (0, 4), requiring the adjustment of the original position vector. The participants emphasize the importance of correctly determining the new position vector to accurately compute the torque.
tmgrich
A particle is located at the vector position r = (i + 3 j) m, and the force acting on it is F = (5 i + 6 j) N.
(a) What is the torque about the origin?
(b) What is the torque about the point having coordinates (0, 4) m?
when you are given an i + j, do you assume that it starts at the origin?
then to you add 4 to the j vector since you are changing the point to (0,4)?
Torque is defined as the cross product r x F, right?
You're given two vectors: r = (i + 3j) m, and F = (5i + 6j) N.
It sounds to me like you're missing the crucial ingredient that the representation r = (i + 3j) is the same as the "vector notation" (1, 3, 0); the representation (5i + 6j) is the same as (5, 6, 0). Can you calculate the vector cross product of those two vectors?
- Warren
Use matrix
Yes, assume that the "position vector" is with respect to the origin (0,0,0).
Since torque is always calculated with respect to (wrt) some point*, when you change that point from (0,0) to (0,4) you must use a new position vector with respect to that new reference point:
Let A = position of particle wrt 0,0 = 1,3
Let B = position of new reference point wrt 0,0 = 0,4
Let C = position of particle wrt 0,4 = ?
You know that A = B + C, so figure out the new position vector C.
*assumed to be in the z = 0 plane in this problem
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
