Velocity at Piston P and angular velocity of link HP help
The discussion revolves around a homework problem involving a slider crank mechanism, specifically focusing on determining the velocity of the piston P and the angular velocity of the link HP. The problem includes parameters such as crank length, connecting rod length, angle of rotation, and rotational speed.
  • Homework-related
  • The initial poster expresses uncertainty about how to approach the problem, having converted the rotational speed from revolutions per minute to radians per second.
  • Some participants suggest labeling the lengths and using trigonometric relationships to express the distance in terms of the angle of rotation.
  • One participant proposes using a formula involving trigonometric functions to calculate the velocity, but encounters negative values, indicating a potential issue with the direction of motion.
  • Another participant emphasizes the need to show effort and suggests using geometric relationships to derive the necessary equations.
  • A later reply indicates frustration with the lack of engagement with earlier suggestions and withdraws from the discussion.
Participants do not appear to reach a consensus on the approach to solving the problem, with some expressing confusion and others providing differing methods and suggestions.
There are unresolved assumptions regarding the application of trigonometry and the specific relationships between the variables involved in the mechanism. The negative value encountered in one proposed formula suggests a need for clarification on the direction of motion.
bobmarly12345
The instantaneous configuration of a slider crank mechanism has a crank GH 10cm long, the connecting rod HP is 50cm. The crank makes an angle of 60 degree with the inner dead centre position and is rotating at 110 rev/min. Determine the velocity of the piston P and the angular velocity of the link HP.
cannot find any simliar examples in textbooks or online which will help me with this question.
Really have no idea where to start but I've made a start whether its right i don't know.
Right, first off I've converted the 110rev/min=w into 11.5Rads/s
so w=11.5Rads/s
i then assumed you had to find the velocity at H in order to find the velocity at P
so Velocity at H = (Wgh) X gh
Vh = 11.5rads/s X 0.1m
= 1.15ms^-1
(i don't know if that is correct for starters & how i use that to find the velocity at P then the angular velocity at HP, please help?)
Before putting all the numbers in, I would label the length of the crankshaft ##c##, and the radius of the wheel ##r##, the distance ##PG = x##. Then write an equation giving ##x## in terms of the angle of rotation ##\theta##. Solve the equations you need before plugging in numbers.
i have an idea of what you mean but I'm still quite lost
You are going to have to show some effort. Drop a perpendicular down from H to the horizontal axis. That breaks ##x## into two legs of right triangles. You should be able to use trigonometry and the Pythagorean theorem to express ##x## in terms of the angle of rotation ##\theta## and the other constants ##r## and ##c##. Ultimately, the velocity of the piston will be ##\frac{dx}{dt}##.
would this formula work, [ -rw(cos(60)+((sin2(60)/(2xsqrt(n²-sin²(60)))) ]
where n = L/R
i get a negative value when i use it, the piston is moving in the negative direction.
I'm sorry, but since you don't seem to care about my suggestions, I am resigning from this problem.
