Solving for Earth's Velocity After Collision with Asteroid
The discussion revolves around calculating Earth's velocity after a collision with a Mars-sized asteroid, using the inelastic collision equation. The user initially calculated a velocity of 29.65 km/s but doubts its accuracy compared to the current Earth's rotational velocity of 30 km/s. Key considerations include the asteroid's impact speed of 10 km/s and the need to account for the direction of impact and rotational energy transfer. Participants suggest that the problem lacks sufficient information for a definitive solution and emphasize making simplified assumptions to proceed. Clarifying these factors is essential for arriving at the correct answer.
smh001
I am trying to solve a physics problem involving the velocity of Earth and primitive earth. I have solved it using m1v1+m2v2=(m1+m2)v2 for inelastic equation and get a velocity of 29.65 km/s. Which I think is incorrect since the Earth's rotational velocity today is 30 km/s. But I can't figure out what I am doing wrong. Any help on how to correctly solve this problem would be greatly appreciated.
Problem: The leading theory for the origin of the Moon suggests that a large asteroid the size of Mars struck the Earth. Some of the asteroid material and some of the terrestrial material combined to form the Moon. Assume the combined mass today of the Earth and Moon equals the combined mass of the primitive Earth and the asteroid. Also assume that the asteroid struck the Earth at about 10 km/s. Assume the collision was inelastic.
How much did the Earth's orbital speed change as a result of the collision
Present Earth -
Mass = 5.97 x 10^24
Velocity = 30 km/s
Moon
Mass = .0735 x 10^24
Velocity = 1 km/s
Need velocity of primitive earth
Thank you for any assistance in solving this problem.
Why do you assume that your answer is wrong? Taking the sun out of the picture and assuming a 2 ball collision, its seems plausible that the Earth was moving slower than vs now.
I went ahead and put in my answer for the difference in change between primitive Earth and present Earth in the online website. My answer for the homework is wrong. Plus being a geology major, it just didn't seem right. I would have thought due to the conditions of the Earth back then, it would have been rotating faster.
I didn't take into account the collision of the asteroid at 10 km/s. I am wondering if I need to in order to get the correct answer.
for sure I'd stick that in as the question tells you do so. Seee if that helps.
The direction of the impact, and whether any rotational energy was transferred should be taken into account. There's not enough information in the OP to solve the problem.
agreed, that's why I think the simplest assumptions possible should be made.
