Velocity of compressed air through pipe
The discussion revolves around calculating the velocity of compressed air exiting a second regulator in an airsoft rifle setup. The air starts at 3000 psi, is regulated down to 800 psi, and then to 40 psi before entering a .25" diameter tube venting to the atmosphere. The challenge lies in determining the air density and velocity after the second regulator, as there are multiple unknowns, including temperature and pressure at the exit point. The conversation suggests that starting from the barrel's exit velocity might provide insights, but the complexity of the variables involved complicates the calculation. Overall, the participants express uncertainty about how to proceed with the thought experiment due to these unknowns.
rcummings89
This started out as a thought experiment and then I realized I was stuck in how to figure it out.
If I have an airsoft rifle that uses compressed air in the tank at 3000 psi. It leaves the bottle regulated down to 800 psi. It then goes into a second regulator that reduces the pressure further down to 40 psi. I want to know what the velocity is when the air exits the second regulator. For the purposes of my thought experiment let's say it goes into a .25" diameter tube and vents into the atmosphere.
At the reservoir I think I can assume the temperature is room temp, but after the two regulators I don't where to go and I don't think I can calculate the density without it to use Bernoulli's equation. I think I have too many unknowns?
So the second regulator feeds into the trigger , which when pulled releases the air , which pushes the slug down the barrel ??
It might be best to start at the barrel end , you know the velocity of the slug exiting the barrel ... , that's the velocity of the air leaving the barrel ... at what pressure ?? ...dia of barrel ... dia of air pipe ... many unknowns ..
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
