Velocity of football kick problem
  • Thread starter Thread starter Phy.Student
    Velocity
To determine the initial velocity required for a football to clear a goalpost 3.1m high from a distance of 45m, kinematic equations for constant acceleration are essential. The ball follows a parabolic trajectory, with horizontal velocity remaining constant while vertical velocity changes over time. Key parameters include the launch angle of 35 degrees, which helps break down the initial velocity into horizontal and vertical components. By establishing equations for the vertical and horizontal motion, one can solve for the initial velocity and flight time. This problem exemplifies a level 3 physics challenge involving projectile motion analysis.
Phy.Student
A football player kicks a field goal from a distance of 45m from the goalpost.
The football is launched at 35 degrees above horizontal.
What initial velocity is required so that the football just clears the goalpost crossbar that is 3.1m above the ground? ignore air resistance.
This question REALLY got me stomped because its considered a lvl 3 question (the hardest there is in this book) and I really have no idea where to begin this...
Welcome to the PF.
What are the Relevant Equations? Write down the kinematic equations for constant acceleration -- those are your starting point.
Then draw a sketch of the geometry of the situation. The ball follows a parabolic arc, no? Its horizontal velocity is constant, and its vertical velocity as a function of time comes from those kinematic equations...
Welcome to the PF.
Well i copied everything that was on that question and the equations that we have been mostly using are
Vf= Vi + a t
Vf^2 = Vi^2 + 2 a d
D = Vi(t) + 1/2 (a) (t^2)
and I'm assuming it would be an arc since its nearly impossible for a football to travel in an uniform line.
Vf= Vi + a t
Vf^2 = Vi^2 + 2 a d
That's not quite all that you need, but is close. The ball starts from the ground and ends up 3.1m high at the end of its parabolic arc. So you have the initial y and final y. And it travels 45 meters horizontally, so you have your initial x and final x. You know the launch angle, so that gives you the vertical and horrizontal starting velocities, in terms of the unknown total velocity. The horizontal velocity is constant (why?), and the vertical velocity varies as you have shown in your equation.
Write two equations and solve for the two unknowns (probably initial overall velocity and the flight time...).
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
