Velocity/Speed Problems (Studying for exam)
  • Thread starter Thread starter LucasG
    Exam
The discussion revolves around calculating the maximum height reached by a ball thrown straight up at 13.5 m/s and finding its velocity at 1.50 m above the starting point. The initial calculations suggest that the maximum height is approximately 9.42 m, but there are concerns about the accuracy due to inconsistencies in the time used in the equations. Participants emphasize the importance of using precise values throughout calculations to ensure accurate results. Additionally, a kinematic equation not initially mentioned is recommended for directly finding the velocity at 1.50 m. Clarifications and corrections are encouraged to enhance understanding of the problem.
LucasG
A person throws a ball with 13,5 m/s straight up. Calculate the maximum height that it will reach from the point where it was thrown. Also find the velocity when the ball is 1.50m above the starting point.
Sorry if the problem is hard to understand, had to translate it from spanish, hopefully it's clear enough.
Vx = V0x + axt
x = x0 + v0xt + 1/2 ax t^2
13.5m/s = 0 + 9.81 * t
13.5/9.81 = t
t = 1.38 s (what it took to reach the highest point)
x = 0 + 13.5 * 1.38 + 1/2 * -9.81 * 1.37^2
x = 9.42 m (maximum height?)
Not sure if the problem is correct, if it's not any guidance is appreciated. I'm also missing what's the velocity 1.50m above the starting point.
t is correct (1.376 s), but you are using 1.38 and 1.37^2 in the same equation. Hang on to the couple extra digits until you have the final result.
You know x0, x, Vx0, and a. There is a kinematic equation that you have not posted that will allow you to find vx directly.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
