Velocity vectors for an object dropped from a moving plane.
The discussion focuses on calculating the motion of a package dropped from a horizontally moving airplane. Key points include determining the time it takes for the package to land, the altitude of the plane, and the package's velocity and speed upon landing, all expressed in terms of variables like 0, L, and g. The user initially struggles with the equations of motion, particularly in finding a solution for time and horizontal distance. After some confusion with the variables, the user ultimately resolves the problem. The discussion highlights the importance of correctly applying kinematic equations to solve projectile motion problems.
flamemonkey
An airplane is dropping an aid package in a remote area. The plane is moving horizontally at speed 0 and the package lands a horizontal distance from where it was released by the plane.
a) Find the time it takes for the package to land. -This is were I'm having the problem and is mostly what is preventing me from doing the rest.
b) Find the altitude of the plane.
c) Find the velocity (vector) of the package when it lands.
d)Find the speed of the package when it lands.
Write your results in terms of 0, L, and g. Check the units/dimensions for each answer.
x=(-g/2)t2+V0t+x0
v=-gt+V0
a=-g
The acceleration in the y-vector is -g/2*t2 and it has an initial velocity of 0 because it is being dropped from a plane moving parallel to the ground. solving for t gave me t=(2X0/g)1/2 then solving for X0 I got X0=v2/2g which is just leading me in circle leaving me with variables that I can't find a value for and are not accepted in the answer.
Nevermind i solved it.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
