Vertical motion with air friction
cscott
An object falling from some point in the air (near the surface) with air friction, R = kv.
So,
m\frac{dv}{dt} = mg - kv
Seperate variables for
\int \frac{m}{mg - kv} \cdot dv = \int dt
and for the LHS I use integration by parts, so,
(m)(mgv - \frac{1}{2}kv^2) - \int mgv - \frac{1}{2}kv^2 \cdot dv = t
am on the right track here?
So,
Your integration by parts is incorrect (I have no idea what you used for ''u'' and ''v'' but there is no way to get what you wrote).
The integral over v is basically a log, that's all.
Woops, I see what I did. Let me try that again.
But it should take the form
(m)\int (mg - kv)^{-1} \cdot dv - \int (1)\left(\int (mg - kv)^{-1}\right) \cdot dv = t
correct?
edit: missed your part about a log. I guess we agree?
correct?
? The first term is the integral you started with! I am not sure where the second term could come from.
You can do the integral in one step, without using integ by parts
asdfakj I wasn't thinking of that m as a constant for some reason :\ I see now, thanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
