Vertical movement of heating plate
To achieve vertical movement of a heating plate, attaching it to a motor is essential. The desired type of motion—whether slow, rapid, step-by-step, or continuous—must be specified to determine the appropriate motor and control system. The mass of the entire assembly is a critical factor that influences motor selection and design. Additionally, safety considerations should be taken into account, especially if the plate will be moved rapidly or in a way that could pose risks. Proper planning and engineering are necessary for effective implementation.
Being Anil
I wish to give a vertical movement to a heating plate. How can I do it?
Attach the heating plate to a motor, what kind of motion do yuo want to give to the plate? E.g. slow, rapid, step-by-step, continuously etc. you also need to take into account the mass of the whole assembly.
Throw it up in the air.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
