Find the Perfect Electric Motor for Your Vertical Wind Tunnel
To achieve a wind speed of 190 kph with a 2.00 meter diameter propeller in an outdoor aerodynamics wind tunnel, selecting the right electric motor is crucial. The discussion highlights the need to consider the type and power of the motor that can effectively match these specifications. Additionally, the design of the wind tunnel, whether recirculating or linear, impacts motor selection. Understanding the desired Reynolds numbers is also essential for optimizing performance. Proper motor selection will ensure efficient operation of the wind tunnel setup.
eyal28
hello. i need to match electric motor to propeller/fan to my outdoor aeroduim wind tunnel.
my requirements goal is to get a 2.00 meter diameter propeller with 190kh wind speed .
which electric motor (type,power) would you think will properly match for this requirements ?
thank you.
That's on the largish size for a livingroom windtunnel. Do you plan on a recirculating or a linear design? What Reynolds numbers do you wish to obtain?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
