VERY quick cross product question
bcjochim07
p X q - r
In order to evaluate this expression, I must first evaluate q - r and then perform the cross product, right? I'm trying to think about X as an operator, like del, that operates on the things that appear after it. Is this correct?
Thanks.
I would think it's the other way around: that you do the cross product first, and then subtract. The only justification I can think of for doing it this way comes from arithmetic--that multiplication and division are to be done before addition and subtraction.
For example, the expression 2*4 - 3 = 8 - 3 = 5. I don't recall seeing this idea extended to vector cross products, though.
The symbol X used in cross products affects the two things on either side of it, not just what follows it, so for that reason it is different from the del operator or the differentiation operator.
Yes, I agree with Mark44. By the standard "precedence" of operations, p \times q- r means (p\times q)- r, not p\times (q- r)
Same with del … ∇A - B ≠ ∇(A - B) :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
