VHF Tuner Circuit: Matching 75Ω Impedance with Tapped Coil
  • Thread starter Thread starter brainbaby
    Circuit
The discussion focuses on matching a 75Ω impedance using a tapped coil (L1) and shunt capacitors (10pF and 15pF) in a VHF tuner circuit. Participants clarify that at resonance, the impedance of L1 and the capacitors cancels out, allowing for optimal voltage coupling to the base of Q1. The importance of calculating the turns ratio for impedance transformation is emphasized, as well as the need to determine Q1's input impedance for accurate matching. Additionally, the role of additional coils (L2, L3, and L4) in mutual coupling and their effect on resonant frequency is explored. The conversation concludes with references to external resources for further understanding of impedance matching principles.
brainbaby
Hi friends,
I want to frame out how 75Ω impedance is matched by using tapped coil and two shunt capacitors connected in parallel. I think so for that I have to calculate the load value, and if we take the entire circuit out to be as a load then the most acute hurdle would to be to calculate the load value of the circuit.
I am completely messed up ..please help..??
Thanks
The 75 ohms is matched by the tap low down on L1. The top of L1 is much higher impedance.
As shunting capacitors, the 10pF in series with 15pF will peak resonance of L1 in VHF band. They then form a capacitive voltage divider that applies RF to the base of Q1.
You should think of the 10 pF as the top of a Pi matching network, with L1 and the 15pF as the two legs. That network matches the high impedance of L1 to the base of Q1.
Likes brainbaby
If you are talking about resonance as what every tuner circuit meant out to be ...then how can we think of that the capacitors would divide voltages...
At resonance the imaginary part of the impedance of coil L1 and capacitors ( 10pf and 15 pf) will cancels each other resulting no current to flow across it causing the voltage from antenna side to perfectly couple to the base of Q1...hence they shouldn't acts as a voltage divider...
also...
please elaborate...
Energy circulates between L1 and the capacitors. A current is flowing in the circuit. The voltage that appears across the inductor also appears across the two capacitors. The two capacitors are in series. The series combination of two capacitors is resonant with L1. Where two capacitors are in series they form a voltage divider.That helps match the LC network to the BJT base.
brainbaby said:
also...
please elaborate...
L1 is an inductor. It is also a transformer because it has a low impedance tap near the bottom, so it can be analysed as an autotransformer. It must also be an impedance transformer. You can analyse the turns ratio to work out the voltage, current and impedance ratios.
Likes brainbaby
This is the main problem of the query. According to text its only 75 ohms impedance that is to be matched, but I don't know the other value of the impedance to which it should be matched i.e the input impedance of Q1, without knowing this value I cannot determine the turns ratio. As turns ratio equals the square root of the impedance ratio...
So is there any way to determine the input impedance...!
The circuit is all there. Model it with spice from antenna to the collector of Q1, then read the theoretical input impedance.
Does this receiver exist? If so, count the turns. If not, redesign L1 based on the spice model.
What type of signals and what frequency range is this VHF front-end supposed to cover?
To manually calculate this conversion I would proceed as follows. Firstly, there is an auto transformer formed by the tapped coil. Find the turns ratio N and square it and so find the new parallel resistance across the coil, RLP = 75 N^2. Now take the reactance of the coil and find the loaded Q = RLP/XL approx. Now find the equivalent series resistance of the coil (in loaded condition) from RLS = RLP / Q^2 approx.
Now find the reactance of the 15pF shunt capacitor X15 (this capacitor operates in a parallel resonance with the series combined reactance of L and the 10pF capacitor, but you do not need to work this out). X15 has a series resistance equal to RLS as they are in a series circuit. Now find the reactance of X15. Find the loaded Q of X15 from Q = X15 / RLS. Now find the parallel equivalent across X15, given by RP = RLS x Q^2 approx. This is the resistance presented to the amplifier.
It is laborious and easy to make a mistake, as I probably have myself!
Likes brainbaby
Then all you now need to know is the L1 inductance, L1 turns ratio and the frequency of operation.
The resistive loading of the RF tuned circuit by the 1k AGC injection makes this look like a low-Q front-end, designed for wide-band TV reception, probably circa 1980.
Where does the schematic diagram come from ?
Likes brainbaby
You also need to know the reactance of the 15pF shunt capacitor, because this dictates the output resistance. And you are right that we also need to take into account the 1k shunt resistors, which I had not noticed.
Likes brainbaby
15pF, Xc is a simple function of the frequency of operation.
Likes brainbaby
brainbaby. Here are a couple of files for LTspice to get you going.
Remove the .txt extension to run the simulation.
Likes brainbaby
The circuit is taken from a book...
Monochrome and color telivision by rr gulati...
and BTW thanks for the files ...I'll get back to you soon...
Hi Baluncore...
I have analysed your simulation files and it has been found very informative...but I want to find out the impedance at point 1,2 and 3...since the resultant graphs are in db/Hz...I want something to be in V/hz for voltages and amperes for currents...
The impedance at point 3 will be zero, at point 2 will be 75 ohm and at point 1 will be higher.
Here are two more LTspice files.
VHF_2 is improved model with cuttable link to see resonance.
VHF_3 is the resonant circuit only, with volts and amps.
Likes brainbaby
Thanks for the helpful reference to the source. I can see how you're not too satisfied with his explanation for this part of the circuit. (Though the earlier chapter on RF stages helps a bit in general terms.) I notice it is also in "TV and Video Engineering" by A.M.Dhake (P.236), so it must be a common circuit.
At least we know now what range of frequencies it might cover (band 1 and maybe band3) and possibly what bandwidth is required (probably a single channel at 7MHz.)
As I said, I'm no expert in this area, just a suck it and see, codge and bodge amateur, so my thoughts for what little they may be worth:
Since the 10pF and 15pF in series is equivalent to 6pF,
at 50MHz to 70MHz L1 needs to be about 1600nH to 850nH
at 175MHz to 240MHz L1 needs to be about 145nH to 73nH
So if we took around 60MHz and 1200nH, and we need about 7MHz bandwidth, then we need a Q of about 8.5, which means a parallel resistance of about 3700Ω. (And this resistance will not change at other frequencies.)
Now I'm probably more in the dark than you about the input impedance of Q1, but we know that there is a maximum about 1kΩ resistance in parallel with the tuned circuit due to the DC biasing circuit. So I don't think they can achieve that Q. Maybe the double tuned collector circuit provides the necessary bandwidth shaping and they just put up with intermodulation effects in the RF stage?
Anyhow, if I guess they are looking at an impedance of around 1kΩ at the tuned circuit, and step up the input to that level.
Tapping L1 at 2:8 would give 1:16 impedance ratio, matching the 75Ω input with around 63Ω, or 2:7 tap giving 82Ω. (Or looking at it the other way, stepping 75Ω up to 1200Ω or 920Ω.)
I'd have thought, your 4nH:400nH tap seems a bit high (though I'm not sure how you've calculated this.) I'd have thought, this would match the 75Ω into about 7500Ω. That would be great if the other side of the circuit could match it, but otherwise seems unnecessarily high. (Or again looking at it the other way, would transform a low Q circuit down to too low an impedance to be a good match for 75Ω.)
I'm not into Spice at all, so I'll await your results on this. I wonder whether you can simply drive the Q1 circuit directly, leaving L1 and the two capacitors out of the equation for now? From your point of view (wondering about impedance matching and tuned circuit tapping) it might be interesting to know the raw load, then see how attaching a tuned circuit and tapping in different ways affects it.
If you like Spice, maybe even forget this circuit and simply set up a tuned circuit with a resistive load and see how driving and loading it via taps affects things. It would take away any variation of Q1 input impedance which might obscure things.
Here is the tuned circuit, load 1k with BW = 4.5MHz.
Driven by a current of 1 amp, the input voltage is 75V, therefore Zin = 75 ohms.
Better approximates reality by lowering turns ratio of inductor. Now fixed the centre frequency, bandwidth, loading and input impedance.
Hi...guys
Moving on to the other part of the circuit let us quickly discussed what we have discussed so far...
My initial query was to discuss the role of C1 and C2 and tapped coil L1 ..which is now clear to me..
Its just a kind of resonant circuit which resonates and provides selectivity and C1 and C2 acts as a impedance transformer which fools the load impedance and make it see the source impedance equal to its value.
Some were the missing values which was not present in the text..however I assume some of them from suggestions to carry forward my analysis...
Aim is to match 75Ω to 3.3k load resistance...
As assumed...
QL=4.9 (loaded Quality factor)
Qul = 100 (unloaded Quality factor)
fc =100Mhz (center frequency)
B.W =20 mHZ (Bandwidth)
Rs=75Ω (source impedance)
RL=3.3k (load impedance)
Ns=2 (primary turns)
Np=8 (secondary turns)Rint = Rs(n/n1)^2
= 75 X (8/2)^2
= 1200ΩRL= Rint (1+Cx/Cy)^23333 = 1200(1+Cx/Cy)^2C1= 0.66 C2Qul = Rp/XpRp = 100XpQL= Rtotal / XpRtotal = Rp//Rs//RL / Xp (Rs-source impedance, RL-load impedance, Rp- parallel resistance of inductor)4.9 = Rp // 882.32/Xp4.9 = Rp.882.32 / (Rp+882.32) XpSubstituting value of RpXp = 171.24ΩXp = 1/wCT171.24 = 1/2pi(100 x 10^6)CTCT= 9.29 pfCT = Cx.Cy/Cx+Cy9.29 = 0.66 C2. C2/0.66C2+C2
Cx=23.36 pf
Cy=15.41 pf
Now moving further in the tuner circuit...
I want to know what is the function of L2,L3,L4 and C2 and C3...?
The text says that is a double tuned mutual coupled via L4 network...but how can it be mutual coupled since L4 is not physically separated from the circuit in order to be mutually coupled...??
Special thanks to Baluncore and Merlin3189!
The coils are presumed to be spaced apart so there is no mutual inductive coupling between them.
Then we find that the currents in the two coils L2 and L3 both flow through L4, which provides "bottom coupling" by providing a common impedance.
The inductance L4 acts the same as the mutual inductance between two magnetically coupled coils. However, its inductance is added to both L2 and L3, which alters the resonant frequency.
Assuming L2=L3, then Coupling Coefficient is L4 / (L3+L4). Radio Engineers Handbook, Terman, p 164.
For critical coupling, kQ = 1. This give the flattest response.
Apart from the book which you have mentioned ...from where else I can get an elaborative explanation of common impedance matching...
This link provides all the information but is perhaps unnecessarily complicated for the present case.
http://frank.pocnet.net/other/RCA/Radiotron_Designers-Handbook_Fourth-Edition/09-Tuned-Circuits.pdf
Likes brainbaby
I don't really agree with that
L2 and L3 are part of a transformer T2 and therefore are most likely to have inductive coupling
don't really agree with that either
It is standard practice to put inductors in the DC lines feeding a stage. L4 along with C1 decouple the DC rail from the RF signal that it feeds
This is to stop RF (AC) from going out ion the DC rail ... If allowed to, it would cause havoc as it caused oscillations on the DC railDave
Likes brainbaby
Of course, we do not know if L2 and L3 have mutual inductive coupling, but from a design point of view it is undesirable. It would require close mechanical tolerances, or adjustment by moving the coils little-by-little. It is better to have shielded and isolated coils and use a known value of mutual coupling provided by L4. It is possible to use a combination of mutual and bottom end coupling, but there seems no point in doing this.
L4 is not used as a decoupling component. It is undesirable to use an inductor for this purpose here because of unwanted inductive coupling. Further, if it were used for decoupling purposes, the capacitor C4 would be placed at the bottom of L4, where its effect would be greater. The 390 Ohm resistor is a decoupling component.
Likes brainbaby
because they are both part of a transformer ... it's 99% probability there is inductive coupling between them
tech99 said:
but from a design point of view it is undesirable. It would require close mechanical tolerances, or adjustment by moving the coils little-by-little..
pointless comment ... the tuning adjustment IS PROVIDED ... L2 is adjustable
absolute rubbish ... coupling between stages using inductors like that is a common practice, there are a number of variations used for interstage coupling. This is just one of them
... maybe you are not a RF tech ?
again not true ... it's standard practice
seriously ... for the 3rd time ... Its standard practice
Dave
PS ... I am happy to be proved wrong by some one more knowledgeable in RF than either of us :smile::wink::biggrin:
Likes brainbaby
some examples of you so called ineffective decoupling that work very well
note particularly C4 and C6 ^
Note location of C4, C5, C6, C7 like the circuit above, they are on the DC side of the RFC inductor
OK ... I think I have made my point :wink::rolleyes:
Likes brainbaby
May I take just one point to start with? You will notice that the current circulating in each of the two tuned circuits, L2-C2 and L3-C3, passes through L4. So how is it not introducing mutual coupling?
Likes brainbaby
only if it were positioned to do so, otherwise it is just a RFC through which the DC is supplied as shown on my many examples
Likes brainbaby
Well, I have watched as you have both put up good arguments in this debate. There is insufficient information on the schematic to be certain of the relative inductor positioning. In summary, on the balance of the evidence, I believe L4 is actually doing both jobs. It plays a critical part as an independent fixed inductor in the mutual coupling, but it is also cunningly installed to function as an RFC.
There is no question that the circuit is a double tuned, mutually coupled bandpass filter of unusual European design. It needs to provide a wide accurately controlled VHF passband while compensating for the BF196 transistor characteristics. The black art of RF design became a science during WW2, but it developed with a different style on either side of the Atlantic. The designer here was almost certainly not trained in the USA, so did not do it in the USA way. This schematic is from the European 'Pro-Electron' school. To me it appears to be in the Dutch style of Philips N.V. of Eindhoven.
The power supply isolation is primarily provided by C1=3nF, with the 390 ohm resistor to the +15V supply rail. The 390R plays no part in setting any stage bias current, it is only there for power supply isolation. C1 is almost certainly a large area ceramic disc capacitor selected for low impedance VHF characteristics. If C1 was any bigger, the price would increase and the VHF performance would suffer. So we can treat C1 as a reasonably good RF ground at VHF.
Although drawn in series, L2//C2 with L3//C3 make two parallel tuned circuits at VHF. But L2 and L3 are wound as T2, a well coupled pair of windings on an air core. At first this appears to be a contradiction; how can there be two independent tuned circuits while L2 and L3 are also a closely coupled transformer?
The explanation is that T2 is only a closely coupled transformer if the common terminal is solidly grounded. Without L4, T2 would remain as a two terminal network. Now we can see why L4 is being used. By introducing the controlled soft grounding of the common reference terminal through L4, the coupling coefficient across the circuit involving T2 can be very carefully controlled by component value. That makes a much more predictable VHF passband, with less need to adjust the coil positioning during manufacture. The difference current between L2 and L3 flows in L4. That difference current is effectively doing the mutual coupling.
Likes brainbaby and davenn
You said that the L4 inductor is just a controlling device which controls the coupling and gives a better control on the EXTENT of the coupled signal…meanwhile I referred to couple of text and found that it also says the same thing that without L4 the coupling will vary at different frequencies of the pass band..and with the use of L4 the coupling will be constant..i.e constant coupling coefficient (k) with non varying response…
Can you rather justify it numerically……
I mean that we knew that the coupling coefficient of simple two inductor coupled circuit is k = M / √Lp.Ls and with mixed mutual bottom inductive coupling it is
k = Lm + M / √ (Lp + Lm)(Ls + Lm) ….so how can one assume that the value of Lm could force to make the value of k constant for any value of passband… ??
Please elaborate the regulative action of L4..??
You can model L2 and L3 as a transformer with a low coupling coefficient m.
You can model L4 as an auto-transformer, or two parallel windings, with a high coupling coefficient M = 1.0
Those two transformers share or blend the coupling in proportion to their impedance.
If I had the time I would model the circuit with Spice.
  • #31
The circuit does not look tunable, so there does not seem much point in having two sorts of coupling in order to maintain constant coupling during tuning. Also, not sure if L2 and L3 are a transformer, and I think that separate coils in cans would be more predictable.
Regarding the value for L4, XC2 is about 300 Ohms and XC3 is about 600 Ohms. SQRT 300x600 = 424 Ohms. Suppose we want to cover about 90 to 100 MHz, requiring a Q of 10, so that kQ=1 and k=0.1. Then the bottom coupling reactance provided by L4 needs to be 424 x 0.1 = 42 Ohms. This is quite a reasonable value.
It is interesting to notice that if L4 is a very high impedance, then the circuit would behave as a pi-network between the two stages. The two tuned circuits would be blended into one, as Baluncore mentions. I think this may be what Davenn had in mind.
  • #32
Then how do you interpret the T2 designation between L2 and L3 like all other transformers on the schematic.
Likes davenn
  • #33
exactly
and again look at L2 within the T2 designation ... it is clearly marked as a tuneable inductor
  • #34
If you compare it with the other cases in the diagram it is different. The inductor spacing is greater and the windings are reversed. But I agree it could be, although it just seems to make things harder during manufacture.
  • #35
What I realized is that I made a little mistake in elaborating what I mean by constant k..actually k tells us about the extent of coupling...and what I actually meant is bandwidth..so what i visualize here.. is that two resonant circuit and each having its different resonant frequency ...and when they are coupled they collectively are resonant at different frequency owing to the mutual inductance...so the circuit would provide output at the two initial resonant frequencies (when the circuits are not coupled) and the third resonant frequency (after coupling)...so it can be just visualised as ...more resonant frequencies, more output...and more bandwidth...
It seems that you provide me some clue about relating Lm with bandwidth...as more the value of Lm more is the mutual impedance and more is the bandwith..
agreeing with Baluncore
so i need to find certain things...
its not L4 that will keep k constant (though which i earlier thought) rather it control the mutual impedance which in return regulates bandwidth...exactly how??
  • #36
We couple two resonant circuits together, both tuned to the same frequency. Each has a bandwidth to the -3dB points of 1/Q. If the coupling is small, the two responses (measured on a dB scale) are added and so provide about the same bandwidth but better skirt rejection. With strong coupling, the response splits into a double peak. With "critical coupling" when k=1, there is a flat response which is about 40% wider than each circuit and with good skirt rejection.
It is possible to tune the circuits to different frequencies, but the end result is the same, assuming suitable coupling is used.
When you said constant k, I thought you meant that k must remain constant as the circuits are varied in frequency, but the tuner shown seems to be fixed frequency.
  • #37
The bandwidth of the RF amplifier needs to cover the whole VHF TV band as it is not tuned with channel changes. The coupling coefficient needs to remain reasonably constant over the entire band. The factory tuning is there to adjust the response at the edge of the VHF TV band.
  • #38
The significant difference between T2 ( L2 and L3) and T3 is that T2 is air cored and T3 is indicating an iron/ferrite core
  • #39
Really I am eager to find out an example which verify constant k over entire frequency range...
As Lm provides common impedance coupling, so for a certain frequency there is a certain inductive reactance XL of Lm (i.e shared) and for different frequencies, XL is also different...when reactance change it also change the value of Lm...and it can be seen that by substituting value of Lm for different-2 frequency in formula k = Lm + M / √ (Lp + Lm)(Ls + Lm) will result in different values of k...which is against our aim...so i find myself not worth going anywhere...??
  • #40
I can't get pictures in the conversation, so I've put it here. (With apologies to other thread readers.)
What I'm trying to show is that the mutual impedance becomes part of both tuned circuits and the tuned circuits are linked by that shared impedance.
The bottom diagram is purely an analogy, showing how the size of a shared impedance can affect transfer between loops.
  • #41
Merlin3189 said:
What I'm trying to show is that the mutual impedance becomes part of both tuned circuits and the tuned circuits are linked by that shared impedance.The bottom diagram is purely an analogy, showing how the size of a shared impedance can affect transfer between loops.
Thanks for the figure ...now I am able to visualize exactly how the signal is coupled, earlier I was thinking that the two resonant circuits (L2, C2 and L3, C3) are coupled by mutual induction..hell I was wrong..
If I am right then equivalent circuit of your last figure would be like this
Now I am solving like this
for second case R=1 and A= 0.08
Now finding Equivalent resistance
1/Req1 = 1/R1 + 1/2R
= 1/10 + 1/2
=10*2/10+2
Req1 = 5/3
Req2 = 5/3 (for other half of the circuit)
Now these resistance are in series so
Req = 5/3+5/3 = 10/3 ohm
But the total resistance should be 125 ohm
as per
V= I .Req
Req = 10/ 0.08
= 125 ohm...
Where I am mistaken...??
  • #42
Yeah, that's my fault introducing the splitting of R. Turned out not to be helpful !
I said
## R1\ in\ series\ with\ (R || R2) = R1 + \frac{R R2}{R + R2} = 10 + \frac{1\times10}{1 + 10} = \frac{120}{11} ##
## \rm {So } IR1= 10\times\frac{11}{120} = 0.917 ##
## \rm {and } VR1[/SUB ]= 9.17 ##
## \rm {making } VR=0.83 ##
## \rm {So } IR2= \frac {0.83 }{R2} = 0.083 ##
(apologies for the Latex. It's playing up today and ignoring it on some lines!?)
In plain text
R1 in series with (R || R2) = R1 + R* R2/(R + R2) = 10 + 10/11 = 120/11
IR1 =10 * 11/120 = 0.917
VR1 = 10 * 11/12 = 9.17
So VR = 10 - 9.17 = 0.83
And IR2 = 0.83 / 10 = 0.083
  • #43
Merlin3189 said:
In plain text
Thanks for your wonderful elaboration and making me understanding the exact fundamental idea of common impedance coupling employed in the circuit.
Your theory seems to be unified with most of what Baluncore have said earlier, and that's a good omen that we are on the right track and have almost understood the circuit and its operation , however some little things do need further clarification such as...
Baluncore post 30# you seem to comply with what he has said in it...
"Those two transformers share or blend the coupling in proportion to their impedance."..absolutely correct!
But in his post 28" you seem to be in little contradiction for what he said...
"The explanation is that T2 is only a closely coupled transformer." and in your post 40# your figure states that "L1 and L2 (i.e L2 and L3 in original circuit) are not magnetically linked..so no transformer action..."
What you have to say on this...!
  • #44
Baluncore was presumably speculating, as was I at the time, as to how the circuit functioned. But having read Mr Gulati further, I saw on page 434 of your reference,
Impedance Coupling
Another form of coupling, that employs a common impedance Zm for mutual coupling between two tuned circuits, is shown in Fig. 22.5 (a). This method is also called band-pass coupling because it usually has the bandwidth of an overcoupled double tuned transformer. In Fig. 22.5(b) coil Lm is common to both the tuned circuits with L1, C1 and L2, C1. As a result, signal voltage across Lm is coupled from one tuned circuit to the other. There is no direct coupling between L1 and L2 and both L1, C1 and L2, C2 are pretuned by means of brass slugs to the same centre frequency. The bandwidth is controlled by the value of Lm. The greater the value of Lm the greater the mutual impedance and greater is the bandwidth. This type of coupling is commonly employed between the RF amplifier and the mixer. Values of Lm and damping resistances are chosen to provide a band pass of approximately 7 MHz.
The original circuit you posted, fig 22.17 says,
The RF amplifier output circuit is double-tuned and mutually coupled through common inductor L4. Note that capacitors C2 and C3 are effectively in parallel with L2, L4 and L3, L4 respectively to provide tuning. The cores of L2 and L3 are adjusted to obtain a broad tuning with peaks at the picture and sound carrier frequencies.
He does not say here that L2 and L3 are not coupled. They could be, but in view of his earlier description of the same layout, I now think they are not.
The coupling can be set by L4 and there is no reason to add transformer coupling.
As for the general issue of coupling varying across a band, as has been mentioned earlier, I now understand that this is referring to cases where L1 and L2 (or L2 & L3 in some diagrams) are linked variable capacitors being used to tune across the band. Here the coupling will vary because the fixed Lm (or L4) will not be a constant proportion of the tuned circuit capacitance. This is then mitigated by providing another form of coupling which varies in the opposite way.
In 22.17 and 22.5 the C1 and C2 are fixed as are L1 and L2 (maybe trimmed during setup), so L4 remains a constant proportion at all frequencies across the band and provides fixed coupling coef't. It is this coupling coef't, along with the tuning and damping of the two tuned circuits, which determines the overall bandpass characteristic.
Likes brainbaby
  • #45
There are three RF amplifier applications for an inductively-coupled double-tuned circuit. The frequencies chosen;
1. Close in frequency, tracked with a ganged capacitor for a tunable narrow band FM or AM channel.
2. On either side of one TV channel. Optimised for the approximate 6 MHz channel, from the vestigial sideband and AM carrier to the FM sound carrier.
3. Far apart and fixed for an entire TV band of channels, eg VHF1, VHF2 or UHF.
I believe the circuit under discussion here is number 2. TV sets once used turret tuners to select the channel. The set of inductors needed for each channel was wound on a strip of bare phenolic card, or a plastic strip or rod.
http://www.modip.ac.uk/sites/modip/images/large/BXL974.jpg
The schematic provided does not show that turret or the wiper contacts, but it does show a fine tuning control, R3 on the LO. So where is the coarse tuning? That must have been done by a channel selection turret. Everything prior to the IF was within that turret tuner module. The active elements were fixed and shared between channels, so only the tuned circuits were on the channel cards. Each card would have had the five inductors from L1 to L5. The T2 coupling for each channel was adjusted by selecting the relative positions of the L2 – L3 windings on that card. This is consistent with the schematic showing no values for the inductors, and giving only a vague hint of proximity coupling for T2.
Likes brainbaby
  • #46
I think this circuit is probably for a VHF Band II tuner rather than a TV tuner, as no indication of channel switching is shown and the circuit could not be broadbanded enough to cover the entire width of Bands I or III.
Likes brainbaby
  • #47
The schematic comes from here: Monochrome and Colour Television. R.R. Gulati - 2009 isbn = 8122416071
" Transistor VHF Tuner. The circuit of a commonly used transistorized VHF tuner is shown in Fig. 22.17. "
"The cores of L2 and L3 are adjusted to obtain a broad tuning with peaks at the picture and sound carrier frequencies. "
Edit; Here is the OCR text extract.
The circuit of a commonly used transistorized VHF tuner is shown in Fig. 22.17. It employs BF196 for the RF amplifier and mixer stages, and BF194-B in the local oscillator circuit. All the three transistors operate in grounded emitter configuration. The 75 ohm impedance of the balun on antenna side is matched to the input of Q1 (RF amplifier) by a tap on coil (L1) and the impedance transforming network formed by the two capacitors (10 pF and 15 pF) which shunt the coupling coil. Forward AGC voltage is fed at the base of BF196 via 1 K resistance and a decoupling network. The 47 ohm resistance inserted in the base circuit helps to suppress any parasitic oscillations. The RF amplifier output circuit is double-tuned and mutually coupled through common inductor L4. Note that capacitors C2 and C3 are effectively in parallel with L2, L4 and L3, L4 respectively to provide tuning. The cores of L2 and L3 are adjusted to obtain a broad tuning with peaks at the picture and sound carrier frequencies.
The output from the RF amplifier is coupled to the base of mixer transistor Q2 through the voltage divider and matching network formed by capacitors C4 and C5. The oscillator output is also fed at the base of Q2 through capacitor C6. The mixer output circuit is double tuned and feeds the first IF amplifier. The 150 ohm resistor across the secondary winding of T3 is a damping resistance to achieve broad tuning.
In the local oscillator circuit, L5 in parallel with a 2 pF capacitor constitutes the tank circuit. The oscillator output frequency is adjusted by varying L5. A varactor diode D is used for fine tuning. As shown in the circuit, it is connected in parallel with the tank circuit. Reverse bias voltage to the diode is fed through the voltage divider formed by R2 and R3. The potentiometer R3 is provided on the front panel of the receiver. It serves as fine tuning control because varying R3 changes the reverse bias voltage and hence the capacitance across the tank circuit. The capacitor C7 blocks dc voltage shorting to ground.
Likes brainbaby
  • #48
Does constant proportion means that voltage at point (XY) or Z will be constant at all frequencies??
This statement seems to say that Lm is acting as a resonant circuit, but since Lm is providing impedance coupling by shared impedance, then what the use of it being in resonant with circuit capacitance.??
What does tuned circuit capacitance involves here, Is it the collective capacitance of C1,C2,C3,C4…??
Please illustrate this anticoupling "another form of coupling"
  • #49
We do not need resonance of L4 to obtain the required mutual coupling. We can use a resistor in this position if required, or a capacitor. Any type of impedance can provide the required coupling coefficient. However, if the circuits were adjusted by a variable capacitor, the Q would rise towards the HF end, and so if kQ is to be 1 at all frequencies, we would prefer a type of mutual impedance which reduces with frequency, rather than one which increases, as does a inductor. A combination of coupling impedances is sometimes used to obtain the desired k as the tuning capacitor is adjusted, and for this purpose mutual inductance can be of either sign, adding or opposing the coupling provided by L4.
Likes brainbaby
  • #50
Hi friends feeling great to be back again...
After research of many days I was able to break down the obscurity of the coupling that has been employed in this circuit...
Here goes the story beside this coupling...
When two tuned circuits are mutually coupled, at higher frequencies particularly at resonance the impedance of the primary circuit is higher which causes the impedance of the secondary circuit to be also high causing increase in gain. The requirement is initially to control this high frequency gain desiring the gain to be constant for all frequencies. Hence to achieve this special techniques are being employed and one of them is involving mutual inductance to manipulate the gain in predetermined way. This discussion is mainly of effective mutual inductance.
In mutual coupling of two tuned circuit the impedance is reflected from primary circuit to secondary.
This transfer of impedance from one circuit to other is mainly because of equivalent mutual inductance denoted by m. There is a difference between mutual inductance M and m.
Mutual inductance M, is generally exist when two coils are in close vicinity to each other and tells us that a change in current in first circuit produces an emf in other coil. The gain of the circuit largely depends upon M and to make gain constant over the whole broadcast range M has to be altered simultaneously. The only way to alter M is either by rearranging the location of the two coils in space or tuning condenser. But moving any two parts within a circuit to alter M for constant gain was not feasible, so a provision was found out so that M can be altered automatically with frequency just by only use of the tuning condenser and this was found out by incorporating equivalent mutual inductance m.
However m is the sum total of various planned and unplanned coupling prevalent in the primary circuit. The modification of primary circuit impedance can cause a desired change in circuit parameters of the amplifier in question.
The eq. mutual inductance seeks to maintain its value constant around every frequency of the vhf broadcast band. This is possible because m has two components one is fixed and other is variable with frequency. This variable component is higher at high frequency. This variable second component is subtracted from the fixed one so m is less at high frequencies and at lower frequencies vice versa making m a little high. So in both of these cases m has been observed to put its value apparently constant thus maintaining gain constant over the whole frequency band.
This action is what I think so Merlin3189 have talked about...
Hoping that I have correctly justified the topic..
