Vibration Damping Help: CR3-100 Damper Cutoff Frequency
  • Thread starter Thread starter Shady99
    Damping Vibration
The discussion focuses on determining the cutoff frequency for the CR3-100 damper in a mass-spring system, particularly for isolating vibrations above 30 Hz. Users are guided to consult the application guide in the catalogue, specifically page 38, to calculate the required natural frequency and maximum stiffness for 80% attenuation. The relationship between static load and stiffness is emphasized, with calculations indicating a static load of 20N and a stiffness of 7.8 KN/m. The importance of understanding vibration transmissibility is highlighted, explaining that attenuation occurs when vibrations exceed the natural frequency. Overall, the conversation centers on practical calculations and understanding the principles behind vibration damping.
Shady99
Hello i was looking at the damper CR3-100 as seen in the pic. Howver from the tech sheet given i cudnt make out what's the cutoff freq of this damper...i mean which is the frequency beyond which it doesn't let the frequency pass...what to make of this KN/m value?
Can you provide a link to that datasheet?
Likes Shady99
I googled it. There is an application guide in the catalogue.
Its a mass spring system. The cut off frequency will depend on the modal frequency of interest (ie what mass is on the spring). Isolation usually starts 1.4x the natural frequency.
So it really depends on how much attenuation of vibraion you want. The catalogue suggests a natural frequency 1/3 the excitation frequency for 80% attenuation.
Likes Shady99
The total mass of the system is 4 kgs resting on two dampers
All you need to do is work through page 38 of the catalogue. What aspect are you struggling with?
Likes Shady99
The system i have needs to be isolated from 30 hz freq...which means anything above 30 hz shud be damped...so how wud i know which freq this under discussion damper wud cut?
You know the mass value - 4kg. So you can use part 1 on page 38 to calculate the static load per isolator W.
You stated that it must attenuate above 30Hz. So this is your 'input excitation frequency'. You can use part 2 on page 38 to work out the required natural frequency of the system to provide 80% attenuation.
From that you can then calculate the maximum stiffness to allow this Kv.
Have a go at calculating these figures.
Likes Shady99
By the way how the units in the last Kv equation are cancelling out??...i mean there is Newton and hertz^2 in the numerator and m/s^2 in the denominator
They look about right to me. So to provide the desired attentuation from 30Hz
W = 20N
Kv = 7.8 KN/m
From the catalogue it states that:
W < Static Max
Kv < Kv of isolator
So from the there are 4 tunes of isolator you posted in the OP. Which one works?
The reason why this works is that once you go past the natural frequency, the vibration is out of phase with the input. So you start to get attenuation. I suggest you read up on vibration transmissibility.
Likes Shady99
W = 20N
Kv = 7.8 KN/m
W < Static Max
Kv < Kv of isolator
The fourth one works...i still don't get how the units in Kv equation cancel out...Chris thankyou so much for the help...Appreciate it
