Violating Second Law of thermodynamics
The discussion centers on the heat transfer between two infinite parallel plates in a vacuum, where one plate is at a higher temperature than the other. It argues that the steady state temperature of the cooler plate will not equal the temperature of the warmer plate due to differing absorptivity and emissivity values, leading to a potential violation of the second law of thermodynamics. Participants challenge the claim, emphasizing that energy transfer in radiation is proportional to the temperature difference, and that definitions of absorptivity and emissivity must be correctly applied. The conversation highlights misunderstandings regarding thermal dynamics and the nature of radiation, with assertions that energy is conserved and not lost. Overall, the thread underscores the importance of accurate definitions and principles in thermodynamics.
bhave
Background:
suppose that we have single body say sphere and nothing else in the universe. Now it will radiate heat depending on its temperature.since its energy is going down its temperature will decrease.Eventually wel have energy in the form of photons and sphere at zero kelvin. thus In practical case, if we reduce the incoming radiation and increase the out going radiations by sutaibly choosing absorptivity and emissivity we will achieve heat transfer from body at lower temperature to body at higher temperature.
let us consider two infinite parallel plates P1 and P2 with vacuum in between them so that only radiation takes place between them
plate 2 is held at temperature t2.
Let us assume the following
Plate 1
Absorptivity a1 = 0.1
Emissivity e1 = 0.9
Temperature t1
Plate 2
abosrptivity a2 = 0.9
emissivity e2 = 0.1
Temperature t2
Then Consider a steady state
I claim that the steady state temperature of Plate 1 is not equal to t2
for steady state the Incoming heat on Plate 1 must be equal to outgoing heat.
Incoming heat = abosrptivity * radiation from plate 2
= 0.1 * 0.1* sigma* t2*t2*t2*t2 ---------equ1
where sigma is stefan Boltzmann constant = 5.67 exp(-8)
Outgoing heat = emissivity * BlackBody radiation at that temperature
= 0.9 * sigma * t1*t1*t1*t1 ------------ equ 2
Thus equating above 2 equations
0.1 * 0.1 * sigma t2*t2*t2*t2 = 0.9 *sigma *t1*t1*t1*t1
Thus we get
0.325 * t2 = t1
Thus if initially both bodies were at same temperature then more heat will leave plate 1 and thus cause cooling without any input of work.
this way we would be violating second law of Thermodynamics.
Note
It is observed that reflection effects cancel each other and are energy associated with reflection is quite low.
The materials with above mensioned properties are available.
we even considered spectral distribution of Emissivity and Absorptivity and found that overall emissivity or overall absorbtivity values of 0.1 or 0.9 can be obtained.
Final word
Can radiation effects violate second law of thermodynamics.
Science news on Phys.org
bhave said:
(snip)Can radiation effects violate second law of thermodynamics.
Nope. Check the definitions for "absorbance" and for "emissivity."
Kindly help me coz i don't get the point ur trying to highlit
Obviously your analysis is flawed. The transfer of energy is proportional to the DIFFERENCE in temperature. If the plates are at the same temperature there is NO energy transfer.
How did you observe this? You may want to look at it again.
transfer of energy is proportional to difference in temperature only in conduction or convection. But in radiation The amount of heat emitted is independant of other bodies sorrounding it.
I worked it out and found that the terms that add heat to after reflection are GP of common ratio (1-a1)(1-a2) which is less than 1. So i got the expression of the form
a2 e1 T1*T1*T1*T1 = a1 e2 T2*T2*T2*T2
Thus giving slight change with final result equal to
T1 = 0.333 T2
You are incorrect. You may, if you wish, calculate the radiation and absorption separately and subtract, but it works out the same: radiation depends on temperature difference.
This is incorrect.
the total energy transferred to one of your plates is the energy received - the energy emitted.
E_t - E_r \sim {T_1}^4 - {T_2}^4
T1 = 0.333 T2
That is one reflection how about the next? and the Next? ... the Next?
This must be resolved via an infinite series.
The "point" is that YOU need to understand the definitions of "absorbance" and "emissivity." Since you haven't taken the time to follow my advice that you check them, I'll spell it out for you this time --- "absorbance" and "emissivity" are two different names for the same property, the coefficients CANNOT be different as you have postulated, your argument left the rails at that point.
Physics is a science in which the definitions have been cut, dried, stuffed, mounted, pickled, and preserved in formaldehyde "forever." It is NOT a science in which intuitive interpretation of definitions, and casual guesses at meanings of terms lead to meaningful trains of thought.
Suggestions that you "check" some aspect of your work are commonly offered in lieu of more severe criticisms of the care with which you have done the background work necessary to prepare your arguments.
You want radiation and the second law? Work your way through Prigogine. If that recommendation is totally meaningless to you, you are in waayyy over your head --- take the intro physics courses, then give it another try.
Integral said:
This is incorrect.
what about emissivity and absorbtivity of two substances. More over the driving force in conduction and convection depends on temperature difference.
See if you don't have any other body in universe no conduction or convection take place from the sole body in universe. Since the energy is transferred from one body to another directly, you need another body for conduction or convection to take place.
but in case of radiation even if you have only one body in universe it will radiate heat.The emitted radiation depends on temperature.Note that the energy is not lost. the energy still exists in the universe in the form of photons.
Thus we can calculate the emitted radiation independant of other body but this can not be done in case of conduction or convection.
In your thought experiment, there is more than one body.
And as Bystander noted, you are also misusing absorptivity and emissivity. Similar, but separate problem.
