- 30,548
- 7,530
That would be Kinetic Energy? What Kinetic Energy does a Coulomb of Charge have?UMath1 said:I do think the charge must possesses energy
Transient state is, as you said, when the battery is connected to the circuit through switch.Then the following events occurUMath1 said:I think I understand it better. But I am not sure exactly what you mean by steady and transient state. Is transient state when the you start the circuit and charges start moving and steady state when flow out of anode= flow in cathode?
Not potential energy.UMath1 said:However, I do think the charge must possesses energy to do so. To move, energy is required.
UMath1 said:There might be no change in energy, but then the electron had to have some energy after leaving the last resistor. But according to kirchhoffs law, the electron loses all of it energy after the last resistor, so it doesn't have any energy to move.
This is referring to the Drude model (?), which has been superceded by a more universal Quantum model. Drude cannot cope with superconductivity, afaiaa and we are treating the connecting wires as having zero conductivity.Mister T said:The situation with the wire is comparable in that the conduction electrons are transferring kinetic energy to the wire's atoms, causing an increase in the wire's temperature.
Is there a difference between zero conductivity, 'ideal' connecting wires and superconductors? The drude model would have to treat the connecting wires as having no collisions and hence would have no voltage drop.Mister T said:I am not talking about superconductors
Absolutely. I already made that point but he seems to have a problem about where and when the Energy is relevant.DaleSpam said:you could easily envision large mechanical systems where potential energy does not change even as large massive objects move from place to place.
sophiecentaur said:Is there a difference between zero conductivity, 'ideal' connecting wires and superconductors?
DaleSpam said:UMath1's point is simply wrong regardless of the underlying model of conductivity and even regardless of the nature of the charge carriers. The voltage is a measure of the potential energy, and it simply does NOT require any potential energy to move. His idea is wrong even in mechanics where you could easily envision large mechanical systems where potential energy does not change even as large massive objects move from place to place.
The point is that UMath1 has a conceptual error about potential and kinetic energy here:Mister T said:I understand the validity of your point. Perhaps you could help me understand its relevance.
In other words, the problem isn't that UMath1 is confused about whether a wire has negligible or zero resistance or superconductivity, but rather that he has a mistaken belief that an object which has zero potential energy also has zero kinetic energy. His stated belief is that Kirchoff's law says that the electron will get to the end of the last resistor and then stop because it runs out of energy. He seems to be confounding having zero potential energy ("loses all of its energy") with having zero kinetic energy ("doesn't have any energy to move").UMath1 said:But according to kirchhoffs law, the electron loses all of it energy after the last resistor, so it doesn't have any energy to move.
sophiecentaur said:Sorry about the zero conductivity gaff. What a plonker.
UMath1 said:The only reason I have this confusion is because initially in the anode the electrons have only potential energy,
UMath1 said:The only reason I have this confusion is because initially in the anode the electrons have only potential energy, if all this potential energy is used up, how can there possibly be any kinetic energy? In other words, any kinetic energy must originate from the potential energy and if all the potential is used up none can be converted. Total Energy in the beginning was eV. In the end it was 0.
As Mister T pointed out above, this is not correct. Electrons throughout the circuit have approximately the same KE.UMath1 said:initially in the anode the electrons have only potential energy
UMath1 said:After the wire is connected, the charge accumulation at the anode pushes electrons in the wire in the direction of the cathode.
As electrons in the wire touching the anode move away, electrons from the anode take their place. Electrons at the cathode are pushed into the anode by the battery, and the cycle continues.
Mister T, it would be a few hours, because electrons don't move in a straight line.
Mister T said:Can you use your model to explain why, then, one doesn't have to wait for a few hours for the car to start? How much time elapses between the time the wire is connected and the starter motor starts turning?
When you say "thermal energy of copper" do you mean just the electronic contribution? Most thermal energy in metals at room temperature is due to lattice. Electron contribution is about 1%, at room temperature. What is that 100J value?The fact that the KE associated with the drift of electrons is much smaller than Fermi energy does not mean that it is irrelevant.DaleSpam said:EDIT: I just ran the numbers for the thermal energy of the copper vs the KE of the electrons for a typical USB charging cable. The thermal energy as about 16 orders of magnitude larger than the electron KE (~100 J vs. 10^-14 J)
