Calc 2: Volume of a Torus Homework - Solve Step-by-Step
In summary, the conversation discusses solving a problem involving finding the volume of a torus by using integration. The first problem was successfully solved by taking the integral of a function. The second problem posed a challenge as it required understanding the concept of rotating a slice around a specific point. After some guidance, it was determined that the radius of rotation for a general point x can be represented by 3-x. This was then applied to the integral to successfully solve the problem.
KevinL
37
http://faculty.tcu.edu/richardson/Calc2/H20090323torusVolume.htm This is a link to the homework.
2. The attempt at a solution
I did number 1 by doing 2 * integral from -2 to 2 of sqrt(4-x^2) = 4pi
The second problem is where I am completely confused and don't know how to do it or even conceptualize it. Trying to look at an example of a similar problem on another site, I tried to do 4pi * integral from -2 to 2 of xsqrt(4-x^2) but it equals 0.
I think if I understand this one ill be able to do the rest of the homework.
You are close. But the x in the second integral is supposed to be the radius of rotation of the slice located at x and rotated around x=3. How far is x from the center of rotation at x=3?
So it should be 4pi * integral from -2 to 2 of 3sqrt(4-x^2) ?
No. If x is -2 the radius of rotation is 5. If x is +2 the radius of rotation is 1. Right? The distance of those points from x=3. What is the radius for a general point x between -2 and 2?
r= 3-x
You've got it. Put that into your integral instead of x.
Related to Calc 2: Volume of a Torus Homework - Solve Step-by-Step
What is a torus?
A torus is a 3-dimensional shape that looks like a donut or an inner tube. It is created by rotating a circle around an axis that is outside of the circle.
How do you calculate the volume of a torus?
The formula for calculating the volume of a torus is V = 2π²Rr², where R is the distance from the center of the torus to the center of the circular cross-section, and r is the radius of the circular cross-section.
What is the difference between a torus and a cylinder?
A torus is a 3-dimensional shape with a hole in the middle, while a cylinder is a solid shape with two circular bases and a curved side. The volume formula for a torus is also different from that of a cylinder.
Why is calculating the volume of a torus important?
Understanding the volume of a torus is important in many fields, such as engineering, architecture, and physics. It can help in designing structures and understanding the properties of rotating objects.
How do I solve the volume of a torus homework step-by-step?
To solve the volume of a torus homework, follow these steps:
1. Identify the values of R and r in the given problem.
2. Substitute the values into the formula V = 2π²Rr².
3. Simplify the equation and solve for the volume.
4. Round the answer to the appropriate number of significant figures.
10K
