Volume of Solid Formed by y=x^2-2 & y=4
  • Thread starter Thread starter bigskilly
The discussion focuses on calculating the volume of a solid formed between the curves y = x^2 - 2 and y = 4, with square cross-sections perpendicular to the x-axis. It suggests that Simpson's Rule is unnecessary for this problem, advocating instead for a cross-sectional area approach. The side length of the square is determined by the difference between the two curves, specifically 4 - (x^2 - 2). The volume can be computed using the integral of the area function, leading to the formula ∫ from -2 to 2 of (4 - (x^2 - 2))^2 dx. The final volume calculation results in 16.
bigskilly
Find the volume of the solid formed with a base bounded by y = (x^2)-2 and y=4 filled with squares that are perpendicualr to the x-axis.
...i think you can find that area using simpson's rule , you can thus proceed to find the volume using the maximum height...yeah i think that should work...
It's really not necessary to use Simpson's Rule. Find an volume by cross-section. In order to do that, you need to develop an equation for the area, in this case a square. By the equations you gave, the length of one side of the square would be 4-[(x^2)-2]. Since the cross-sections are perpendicular to the x axis. You can leave the function as is since it is already in terms of x. So the formula for volume by cross-sections is
\int^a_b A(x)\delta x
so after finding your a and b, (set the equations equal to each other)
you get the \int^2_{-2} {4-[x^2-2)]}^2 \delta x=16
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
