Volume of three shared cylinders
  • Thread starter Thread starter physics_freak
    Cylinders Volume
physics_freak
Calculate the volume of the space enclosed by three cylinders x2+y2=1, x2+z2=1, and y2+z2=1.
Triple Integral.
change to polar coordinates
If x^2+z^2=1 and y^2+z^2=1 then x^2=y^2=1-z^2. The cross sections of your surface are squares integrating dz. I definitely wouldn't change to polar coordinates.
What is the range of z if I integrate w.r.t z?
What's the range of z on the curve x^2+z^2=1?
is it (+/-) sqrt of 1-x^2?
Those are the values for single value of x. Suppose you consider all possible x?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
