Vortex shedding is mandatory for all the bluff bodies ?
  • Thread starter Thread starter eswarm21
    bodies Vortex
Vortex shedding is not mandatory for all bluff bodies, as it depends on the shape and flow dynamics around the body. Certain conditions, such as low Reynolds numbers, can prevent vortex shedding even in typical shedding shapes like spheres and cylinders. Conversely, an airfoil can experience vortex shedding at high angles of attack despite being known for stable flow. The discussion also highlights that buoyancy, driven by gravity, plays a significant role in submerged structures in water, which can affect load calculations and vortex behavior. Understanding these dynamics is crucial for accurate modeling in fluid mechanics experiments.
eswarm21
Vortex shedding is mandatory for all the bluff bodies ??
for example, flow over a low thickness flat plate with zero attach angle and flow over the very low depth dish antenna (like U shape)
is there any shape (with particular conditions) is exempt from shedding... ?
I don't think many people would consider a flat plate a bluff body. At any rate, not all bluff bodies undergo vortex shedding. It will depend on the separation dynamics, which depends on the shape and the flow around the body. Take, for example, Stokes flow. You can have a sphere or a cylinder, two bodies noted for their shedding behavior, and if the Reynolds number is tiny, you have no shedding. On the other hand, you could have an airfoil shape that normally has no shedding but when it gets to a high enough angle of attack, the flow over the upper half separates and vortex shedding occurs.
Likes 1 person
The term 'mandatory' suggests that vortex shedding has been decreed by some agency.
Vortices are formed because real fluids (air, water, etc.) are affected by friction when flowing over a body.
Thanks for quick reply !...One more ...i would like to study air load on structure .. But i am going to use water as a medium in wind tunnel experiment. I am matching with Re and St numbers . Now will gravity affect the solution (thermal effects are negligible) in terms of load on structure and vortex shedding? if so what we need to be done in this case?
Well in the sense that buoyancy is gravity-driven, then yes. If you are studying forces on something submerged in any fluid, buoyancy exists. In air it is usually negligible. In water it is often important.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
