How Long Would It Take to Drain a Cubic Mile of Water Through a One Square Inch Opening?
In summary, it would take about 255 years for a cubic mile of water to drain if at the bottom there is a one square inch opening.
uhuge
Neglecting evaporation, if you have a cubic mile of water (1 mile by 1 mile by 1 mile) how long would it take to drain if at the bottom there is a one square inch opening?
I am verifying my answer with some really bright people. You
Why don't you at least tell us how you arrived at your answer? :)
Well barring evaporation, I used Toricelli's theorem. Velocity = the sqr root of 2gh. THis gave me the exit velocity at the opening.
Realizing that flow rate is equal to velocity time area of the opening, we can solve for time to drain a certain amount of the tank. The problem is h (height of the fluid) is constantly changing so the formula must be continueously recalculated.
I have a number, I just want to see how close I actually am with my estimation.
I think you should get something like:
[tex]t = \frac {2A}{a} \sqrt {\frac {H}{2g}}[/tex]
where A is the cross sectional area of the water, a is the area of the opening and H is the starting height of the water. Is that consistent with your analysis?
this is fairly close to what I estimated in terms of ballparks. I came up with 2312 years and some change, in running your formula I got right at 2100 years.
mistake
I think i made a mistake in that when I do your calculations I get 21005.32 years. Is this what you get?
uhuge,
I got about 2300 years when I used my formula. Check your units carefully.
Instead of remembering the formula , just apply the Bernoulli's Theorem at the top of the water surface and at the bottom ( bottom means the square peg) . And then calculate your answer and remember converting given units in standard form.
BJ
2300 is about right(the average velocity can be presumed as half the velocity calculated from initial gravity head). If the ridiculously high velocity won't damage the system, it may take another 255 years due to a 0.9 coefficient of discharge.
What is water flow?
Water flow refers to the movement of water through a particular system or environment.
What factors affect water flow?
The factors that affect water flow include the slope of the land, the type of soil, the amount of vegetation, and the presence of obstacles such as rocks or debris.
How is water flow measured?
Water flow can be measured using various tools such as flow meters, current meters, and stream gauges. These devices measure the velocity and volume of water moving through a specific area.
Why is understanding water flow important?
Understanding water flow is important for a variety of reasons. It can help predict and prevent floods, manage water resources, and protect ecosystems. It is also crucial for various industries such as agriculture, energy production, and transportation.
How can water flow be managed or controlled?
Water flow can be managed or controlled through various methods such as building dams, levees, or other structures to regulate the flow of water. Additionally, implementing sustainable land management practices, such as planting vegetation, can help regulate and slow down water flow.
  • Mechanics
11K
  • Mechanical Engineering
  • General Math
