Find the Best Water Pressure Sensor for Your Tank
For measuring water height in a tank, a pressure sensor is recommended to be placed at the bottom, where it can accurately gauge the water pressure. Alternatives discussed include using a float mechanism with a potentiometer or employing a compressor to measure air pressure needed to create bubbles at the tank's bottom. Concerns about immersing electric cables in water highlight the need for safer measurement methods. The feasibility of using a scale based on water's weight was also mentioned, though it may lack precision. Ultimately, selecting the right sensor or method depends on the specific application requirements and maintenance considerations.
hisham.i
I have a water tank, and i want to make a circuit that measures the water height, and display the value on a 3 seven segment display as a percentage of the total height.
So am searching for a pressure sensor that i want to put in the tank.
Can anyone advise me for a sensor number that i may use for such application.
I search on google, and i found many types of pressure sensors but i don't know which one i should use for my application.
Thanks
Something like this?
http://www.omega.com/prodinfo/pressuretransducers.html"
I don't think this will fit the application, since the sensor should be immersed in water( at the bottom of water tank).
I think i need something like the sensor that measures the level of benzene in cars.
Can't you just use a scale? You have a known volume (the tank) and water is 1kg per liter. Okay, so 1kg per liter probably isn't totally accurate but it's pretty close and probably going to have about the same precision as what you're proposing. Anyway, you could always account for that by recalculating how much 1L of water weighs by measuring the ambient temperature and pressure.
That's one way to do it...
A water tank will normally have a pipe outlet near the bottom and the pressure in this pipe will be the same as at the bottom of the tank when no water is flowing.
So this would be a convenient place to put a pressure sensor. You then don't have to have electric cables immersed in water.
Another approach is to have a small compressor and blow air down a pipe in the tank until bubbles come out of the end of the pipe near the bottom of the tank. The air pressure needed to do this will depend on the depth of water in the tank.
You only need to do this when a reading is being taken.
This also avoids having electric cables immersed in water, which is always a high maintenance problem.
The fuel gauge in a car is operated by a float rotating a potentiometer. You can do something similar by having a float rise with water level and rotate a pulley which turns a potentiometer.
You can get 10 turn potentiometers, so you could work out the pulley diameter depending on the depth of your tank.
If the tank was 2 M deep, each turn of the pot would need 20 cm of pulley circumferance so the pulley would have a diameter of 6.3 cm or 2.5 inches.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
