What is the equation for simple harmonic motion with A=14cm and ω=3.0Hz?
The equation for simple harmonic motion with an amplitude of 14 cm and a frequency of 3.0 Hz can be expressed as y(t) = 14 cos(ωt), where ω is the angular frequency. The angular frequency is calculated using the formula ω = 2πf, resulting in ω = 6π rad/s for this scenario. The relationship between frequency (f), period (T), and angular frequency (ω) is crucial, with f = 1/T and ω = 2πf. Understanding these relationships is essential for solving problems in simple harmonic motion. Mastery of these concepts aids in grasping the dynamics of oscillatory systems.
negation
Write a simple harmonic motion with amplitude 14cm , frequency 3.0Hz , and maximum displacement at t=0.
y (t) = A cos (ωt) = 14 cos (2πt/T)
Dealing with angular frequency is easy. But deal with natural frequency throws me off course.
Physics doesn't require much memorization compared to other fields of study. But here are a couple of relationships that are exceptions, and you might want to commit them to memory:
f = \frac{1}{T}
\omega = 2 \pi f
Where T is the period, ω is the angular frequency (i.e., radial frequency), and f is the simple frequency (i.e., ordinary frequency). (Some textbooks represent the simple frequency with the Greek letter nu, \nu, which looks too much like a 'v' to me, but it's often used anyway. Just be aware of that.)
Likes 1 person
f = \frac{1}{T}
\omega = 2 \pi f
Thanks. Frequency is the number cycles per second. In order to have it converted to radians, and by definition of one cycle = 2 pi, the product of f and 2pi gives radians s^-1
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
