Wavelength of an electron homework
Jules18
De Broglie postulated that the relationship λ=h/p is valid for relativistic particles. What is the de Broglie wavelength for a (relativistic) electron whose kinetic energy is 3.00 MeV?
-Electron has 3.00 MeV (or 4.8*10^-13 Joules)
-it's relativistic
-finding λ.
h=6.63*10^-34
λ=h/p (obviously)
And I'm not sure if they're needed, but the relativistic eq's are:
KE = mc^2/sqrt(1-(v/c)^2)
p = mv/sqrt(1-(v/c)^2)
I'm not sure if this one applies to relativistic speeds:
E = hc/λ
Attempt 1:
E = hc/λ
4.8E-13 = (6.63E-34)(3E8)/λ
λ = (6.63E-34)(3E8)/(4.8E-13)
λ = 4.14E-13 m
BUT answer key says 3.58E-13
If you could help, that would be great.
Sorry if it's too long, and I'm a little unfamiliar with relativistic eqn's so forgive me if I screwed up on them.
The equation you used, E = hc/\lambda, only applies to photons (or massless particles in general). So you're not going to need that one here. If you're familiar with the equation
E^2 = p^2c^2 + m^2c^4
I'd use that. If not, you can get the velocity from
E = \frac{mc^2}{\sqrt{1 - v^2/c^2}}
(note that that's total energy, not kinetic energy) and compute the momentum from that.
Thanks very much for the help.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
