Weight causing a wheel to rotate
In summary, the conversation discusses solving for angular acceleration using rotational kinematics and equations for tension and acceleration. The tension in the string is not equal to the weight of the hanging mass and another equation is needed to solve for the tension and angular acceleration. The conversation ends with the correct solution being found.
JamesGold
39
I_solidcylinder = .5mr^2
I_thinring = mr^2
torque = I*Ω (where Ω = angular acceleration)
change in theta = .5(Ω)(time^2)
Attempted to solve for angular acceleration:
(2.5)(9.8)(0.1) = (3*0.25^2 + 0.5*4*0.1^2)Ω
Ω = 11.8 rad/s/s
which I then plugged into the rotational kinematics formula:
Δ∅ = 0.5*11.8*0.5^2
which gave me a wrong answer. Where'd I go wrong?
The torque causing angular acceleration is provided by the tension in the string.
But is this tension equal to the weight of the hanging mass?
Note that the hanging mass is accelerating downwards.
I don't see why it wouldn't be. Can you explain why it isn't?
What if you had two blocks connected by a string and dropped them over a balcony, would the string have a tension equal to the weight of the lower block?
Is the hanging mass accelerating downwards?
I'm not sure. Wouldn't it depend on the relative weights of the two blocks?
Yes.
So if the hanging mass is accelerating which is the greater force, the tension upwards or the weight of the mass downwards?
The weight of the mass downwards.
Correct.
So mg - T = ma?
Hence the tension is not equal to the weight.
The torque is provided by the tension and this tension is still unknown.
But one can obtain another equation so that one can find the tension.
JamesGold said:
So mg - T = ma?
exactly.
Then how do you find the acceleration of the block?
The linear acceleration is related to the angular acceleration.
Note that
for distance there is, x = rθ
hence for velocity there is, v = rω
and for acceleration there is, a = rα
I used α instead of Ω for angular acc
Right... but without knowing the tension of the string, I don't see how we can calculate the angular acceleration of the wheel or the acceleration of the block.
We have two equations:
1...torque eqn for rotational acc
2...f = ma for linear acc
get linear acc 'a' in terms of the ang acc
and then eliminate tension from these two equations.
Okay, so I have now:
String tension * moment arm = I of system * ang acc
[ (2.50)(9.80) - (2.50)(0.1)α ] * 0.1 = (0.02 + 0.1875) * α
Is this correct?
Yes.
Got the right answer. I can't thank you enough, selfless sir.
Welcome to Physics Forums, the site which helps those who help themselves.
1. How does weight cause a wheel to rotate?
Weight causes a wheel to rotate through the principle of torque, which is the force that causes an object to rotate around an axis. When an object, such as a wheel, has weight acting on it, it creates a force that is exerted on the surface it is touching. This force, combined with the shape and placement of the wheel, causes it to rotate.
2. What role does gravity play in the rotation of a wheel?
Gravity is one of the main factors that affects the weight of an object. The force of gravity pulls the object towards the center of the earth, and this force creates the weight of the object. In the case of a wheel, the weight of the wheel and any additional weight placed on it creates a force that is exerted on the surface, causing it to rotate.
3. How does weight distribution impact the rotation of a wheel?
The distribution of weight on a wheel can greatly impact its rotation. If the weight is evenly distributed, the wheel will rotate smoothly and evenly. However, if the weight is unevenly distributed, it can cause the wheel to wobble or even stop rotating altogether. This is why it is important to evenly distribute weight when balancing a wheel.
4. Can weight affect the speed of a rotating wheel?
Yes, weight can affect the speed of a rotating wheel. The more weight that is placed on a wheel, the more force is exerted on the surface, causing it to rotate faster. On the other hand, if weight is removed from the wheel, the force exerted on the surface decreases, resulting in a slower rotation.
5. How does friction play a role in the rotation of a wheel due to weight?
Friction is the force that resists the motion of two surfaces that are in contact with each other. In the case of a wheel, friction plays a role in the rotation due to weight by creating resistance between the wheel and the surface it is rolling on. This resistance can affect the speed and smoothness of the rotation. However, it is also necessary to have some friction for the wheel to grip the surface and rotate effectively.
