Weird problem for finding load resistance value.
3 replies · 3K views · last reply
Vasile Ghe
Hello 2 all !
I am a student on electrical engineering, and i have the following problem to solve:
An electrical circuit includes a dc voltage source with an internal
resistance, and a load resistance. Determine the value of the load resistance R (with a precizion of 0.1 Ω) for which the power delivered by the source will be maximum, knowing that U = 12V and rs = 2.5 Ω.
If i understand the problem correctly, the maximum power transfer occurs when the load resistance value equals the internal resistance of the source.
Is this not correct ?
Why am i asked to calculate the load resistance with a precision of 0.1 Ω ?
Is there something that i am missing here ?
I am attaching the circuit schematic as a reference.
Thank you very much for taking the time to answer my question.
Vasile Ghe said:
Hello 2 all !
You are correct that maximum power is transferred when the load impedance equals the complex conjugate of the source impedance (or in the case of pure resistances, when the resistances are equal).
I have no idea why they mention the 0.1 Ohm number...
Do they want you to derive the result, or just state it?
I guess they want me to calculate it.
I think i have to get several values for resitances and calculate power for each one and thus prove that the maximum power transfer occurs when the load resistance/impedance equals the internal resistance/impedance of the source.
The problem is that i need to do this in Scilab.
How can i do this in Scilab ?
Can you give me an example ?
Thanks
Thanks
You would normally show it using the traditional optimization technique from calculus (set derivative equal to zero). If you have to simulate it, just run through a range of values, or do an optimum seeking algorithm to zero in on the optimum value.
