Welcome to My First Post: A Beginner's Guide
  • Thread starter Thread starter tryingtounderstand
    Welcome
The discussion revolves around combining resistors to achieve a specific resistance value, focusing on the use of four given resistors with different resistances. The subject area is electrical circuits, specifically resistor combinations.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants explore methods for combining resistors to reach a target resistance, questioning whether each resistor must be used exactly once. Some suggest strategies like removing common factors and looking for pairs that can be combined in parallel.
The discussion is active, with participants sharing thoughts on potential tactics for combining resistors. There is an acknowledgment of the requirement to use each resistor exactly once, and various approaches are being considered without a clear consensus on the best method.
Participants are working within the constraints of using each resistor exactly once, which may influence the strategies discussed. The original poster expresses uncertainty about the posting context, indicating a beginner's perspective.
tryingtounderstand
Having a hard time finding a perfect combination for desired equivelant resistance
For example if we have 4 resistors;
6 ohm/ 9 ohm/ 18ohm /12 ohm
Is there a method to combine them to equal to 6 ohm without wasting time trying different variations
This is my first time idk if i posted in the correct sub
Do you have to use each exactly once?
Yes
Yes
There are some tactics...
You can remove a common factor.
Look for pairs which, put in parallel, give simple equivalents.
  • Sticky
12K
  • · Replies 20 ·
