What Are the Energy Transitions in a Hypothetical Atom When Exposed to Light?
The discussion revolves around the energy transitions of a hypothetical atom with a ground-state energy of -10.0 eV when exposed to light at wavelengths of 207 nm and 146 nm. The calculated photon energies for these wavelengths are approximately 5.99 eV and 8.49 eV, respectively. The first and second excited states are determined to be -4.01 eV and -1.51 eV, based on the energy absorbed from the photons. The wavelength of the emission line corresponding to the transition from the second excited state to the first excited state is calculated to be approximately 495.31 nm. The calculations emphasize the importance of using the correct units and equations for energy transitions in atomic physics.
m_physics
1. Problem:
The ground-state energy of a hypothetical atom is at -10.0eV. When these atoms, in the ground state, are illuminated with light, only the wavelengths of 207 nanometers and 146 nanometers are absorbed by the light atoms (1 nanometer = 10^-9meters).
(a)Calculate the energies of the photons of light of the two absorption-spectrum wavelengths.
(b)Complete the energy level diagram shown below for these atoms by showing all the excited energy states.
(c)Show by arrows on the energy-level diagram all of the possible transitions that would produce emission-spectrum lines.
(d)What would be the wavelength of the emission line corresponding to the transition from the second excited state to the first excited state?
E=13.6 [(1/ni^2)-(1/n2^2)]eV
En=-(13.6eV)[(Z^2)/(n^2)]
(1/λ)=(2pi^2mk^2e^4/h^3c)[(1/nf^2)-(1/ni^2)]
2pi^2mk^2e^4/h^3c = 1.097 x 10^7 m
E = hc/λ
hc=1.24 x 10^3eV
(a)
207nm = 2.07 x 10^-7m
146nm = 1.46 x 10^-7m
E = hc/λ
E1=[(1.24 x 10^3eV)/(2.07 x 10^-7)]
E1=5.99 x 10^9
E2=[(1.24 x 10^3eV)/1.46 x 10^-7)]
E2=8.493 x 10^9
(b)
I assumed it was bohr model...(?)
Ground state is at -10.0eV
First excited state is 1/4 of ground state
=(1/4)(-10.0eV)
first excited state=-2.5eV
Second excited state is 1/9 of ground state
=(1/9)(-10.0eV)
second excited state is -1.11eV
sorry about the terrible picture...
(c) is included in picture (?) squiggly arrows..
(d)
ni=2
nf=1
(1/λ)=(1.097 x 10^7 m)[(1/(1)^2)-(1/(2)^2)]
(1/λ)=(1.097 x 10^7 m)[(1/1)-(1/4)]
(1/λ)=(1.097 x 10^7 m)(1-0.25)
(1/λ)=(1.097 x 10^7 m)(0.75)
(1/λ)=8.2275 x 10^6
1=(8.2275 x 10^6)λ
λ=(1/8.2275 x 10^6)
λ=1.2154 x 10^-7m
E = hc/λ
hc=1.24 x 10^3eV
Right number, wrong units. It's actually 1.24 x 103 eV·nm
(a)
E = hc/λ
E1=5.99 x 10^9
E2=8.493 x 10^9
Not quite. Try calculating E1 and E2 again, using the correct units for hc (eV·nm) and λ (nm).
(b)
Not a bad idea, but then the absorbed wavelengths would turn out to be different than the ones they said. So it turns out this one does not follow the Bohr model.
Instead, you can use E1 and E2 to figure out where the energy levels are.
So to try this again.
For part a)
E1 from 207nm lambda comes out to be 5.99 and E2 from 146nm to be 8.4935
For part b)
You draw those two levels as excited states on the diagram
Then for part d)
I keep thinking of using the same (1/lambda) equation to find the wavelength with nf being 2 and ni being 1 but since this isn't a bohr model, that equation doesn't apply..(?)
Meaning... I would have to use I would have to use E1 and E2 ...
Find the energy w/i E1 and E2 by taking E2 - E1
-8.49-(-5.99)
giving me DeltaE = -2.503eV
Then setting that total e and rearranging E=(hc/lambda) to find lambda giving me
Lambda = (hc/E)
Lambda = [(1.24 x 10^3eV*nm)/(-2.503eV)]
Which gives the final answer lambda = -495.406... 495.406nm wavelength of emission??
Correct? Maybe not?
For part a)
You're getting there!
Those are the correct energies of the photons.
If a ground state atom absorbs a 207 nm photon, it's energy will be 5.99 eV higher than it was in the ground state. So, what would be the energy level after absorbing a 207 nm photon?
a) Calculated E1 = 5.99eV and E2 = 8.49eV as energies given off
b) From ground state, -10.0eV + 5.99eV gives me -4.01eV
-10.0eV + 8.49315 gives me = -1.50685eV
Meaning on my diagram, the first excited state would be -4.01eV and second being -1.50685
d) using lambda = (hc/E)
I first find the energy difference from n=2 to n=1
-1.506 - (-4.01)
change in E = 2.5035eV
Then substituting lambda = [(1.24 x 10^3eV*nm)/2.5035eV)]
lambda = 495.307m
Looks good :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
