What caused the low pH in my Tris-HCl buffer?
  • Thread starter Thread starter rockind78
    Buffer Preparation
The discussion focuses on the preparation of a 0.5M Tris-HCl buffer at pH 8.08 using Tris base and concentrated HCl. The user initially miscalculated the required amounts, leading to a low pH of 1.0. Correct calculations indicate that 12.11 grams of Tris base should be dissolved in 100 mL of water, with concentrated HCl added to adjust the pH. The importance of temperature on Tris pH stability is also emphasized.
  • Understanding of buffer preparation and pH adjustment
  • Knowledge of the Henderson-Hasselbalch equation
  • Familiarity with molarity calculations
  • Experience with Tris base and concentrated HCl
  • Learn about the Henderson-Hasselbalch equation for buffer calculations
  • Research the effects of temperature on Tris buffer pH
  • Explore methods for accurate pH measurement and adjustment
  • Study the properties and applications of Tris buffers in biochemical experiments
Researchers, laboratory technicians, and students involved in biochemistry or molecular biology who need to prepare and optimize buffer solutions.
rockind78
I don't know if I can effectively convey what I am doing here, but I am going to try because I need the help. I am trying to determine my ratio of acid to base and subsequently make a .5M Tris-HCl buffer utilizing Tris base, and concentrated HCl.
By my calculations I get a 19.05 parts acid/1 part base ratio.
Using this, I divide the total amount of buffer I am looking to make (200mL) by the total number of parts in solution (20.05 or 19.05+1). Given this, I get ~190mL acid to 10 mL base.
Here is where I was a little unsure of myself. To calculate the amount of base I need, I multiplied the MW of Tris-base (121.4 grams/mole) by the molarity of the solution by the number of mL specified above (10mL).
To calculate a 190mL of a .5M solution of HCL, I used (C1)(V1)=(C2)(V2), where C1=.5M, V1=.19 Liters, C2=11.6M (molarity of concentrated HCl). From this, I calculated that I needed to add 8.2mL of conc. HCl to 181.8mL dd H20.
The final step was to add my acid solution to my base solution.
NOW FOR THEMILLION DOLLAR QUESTION!
I tested some of this "buffer" on pH paper and got a pH of just above 1.0. Why?
The stated pKa value seems to fluxuate between 8.08 and 8.3. I was using 8.08 in application to HH.
Any input would be very much appreciated.
Thank you.
Chemistry news on Phys.org
The problem is quite straightforward. You are asked to prepare a 200 mL solution of 0.5 M Tris buffer at pH 8.08. You only calculated to prepare 10 mL of 0.5 M Tris. You need to add 12.11 grams of Tris base (according to my calculations) to have, at the end, 200 mL of 0.5 M Tris buffer at pH 8.08.
My suggestion? Weigh out 12.11 grams of Tris base. Add to 100 mL of water. Carefully pH with HCl (or NaOH if you get too fancy free with the HCl). Bring up to 200 mL with water. And there you go.
FYI, be careful with temperature. Tris is temperature dependent when it comes to pH.
My calculation just so you can take a look: (0.2 L buffer) * (0.5 mol/L) * (121.1 grams/mol) = 12.11 grams Tris base
Mike has an easy way to do it, however, it would be better if you just used the Henderson-Hasselbach equation. You could easily pull all your info from there.
9K
9K
14K
