Should You Graph All Trials or the Average in a Planck's Constant Report?
  • Thread starter Thread starter Procrastinate
    Data
When preparing a report on Planck's constant, it is advisable to graph all three sets of trials rather than averaging them first. Each trial is independent and may contain its own systematic errors, which can be obscured by averaging. Presenting all trials allows for a clearer representation of the data and its variability. This approach enhances the report's accuracy and reliability. Understanding this methodology will aid in improving future practical reports.
Procrastinate
I'm doing a practical report on Planck's constant and I have three sets of trials. Is it better to graph all three of them and put them in the report or find the average of the three trials and then graph it and put it in?
There are no anomalies and all three of the data have very similar results, so which one should I choose?
I need to know because it will help me in future when writing other practical reports and to be more selective with my data.
If I'm understanding you correctly, it would be incorrect to average the three trials and then plot the result. Each trial is independent with it's own systematic errors. Your result should be the average of the three end results from the trials.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
