What Determines the Maximum Speed of a Ball Fired from a Toy Cannon?
  • Thread starter Thread starter wachaif
    Cannon Energy
The maximum speed of a ball fired from a toy cannon occurs 4.6 cm after release, reaching a speed of 1.79 m/s. Initially, the spring force exceeds the friction force, causing the ball to accelerate. The ball continues to gain speed until the spring force equals the opposing friction force. At this equilibrium point, the ball achieves its maximum speed. Conservation of energy principles can be applied to calculate the kinetic energy at this point.
wachaif
A toy cannon uses a spring tp project a 5.3 g soft rubber ball. The spring is originally compressed by 5 cm and has a force constant 8N/m .When the cannon is fired , the ball moves 15cm through the horizontal barrel of the cannon ,and there is a constant friction force of 0.032 N . between the barrel and the ball.At what point does the ball have maximum speed ? What is this maximum speed?
The Point the ball attain the Max speed is 4.6 cm after release
The Max Speed is 1.79m/s
Can anyone show me the step to obtain the answer ?THX
Here's the idea. At first, the force exerted by the spring is greater than the friction force that opposes the motion. So the ball accelerates until the spring force equals the friction force. That's the point that the ball has max speed. Find that point.
Then use conservation of energy to find the KE at that point.
Thanks you .I got it
