Billygibson2
- 4
- 0
Would a DC motor that had torque of 0.34 Nm be able to generate enough power to rotate a platter that weighs 6 - 10lbs
I am using a chain not belt, and the shaft would use gears to generate rotation of the platter, but thank you very much for your help.anorlunda said:Will you attach the motor's shaft directly to the turntable shaft? Or will you use something like this belt drive?
Or perhaps one where the motor shaft rubs against the turntable rim?
Key parameters are turntable RPM? motor RPM?
Billygibson2 said:I am using a chain not belt, and the shaft would use gears to generate rotation of the platter, but thank you very much for your help.
