chapz said:
What is the definition of a period in a simple pendulum motion?
from the information I've found and what you have told me, I think it is the time taken for the weight to swing from one end to the other and back? That is considered as ONE period right?
This is correct, one period is defined as the time it takes for the pendulum bob to return to it's original position.
chapz said:
But with the experiment, I am provided with a pendulum and the other equipment I have to figure out what I'm going to use and why. I know I need a stop watch to time the period, but as you said it will be difficult to measure the period due to the reaction time!
I'm confused. Please help!
As mentioned before, you will need a few different size lengths of string, a protractor, different masses and a stop watch.
The longer your strings are, the easier it will be for you to take those measurements (this should come through intuition).
When measuring the period, by starting your stopwatch a couple of periods after you release the bob, you will give the pendulum time to 'settle' a little bit (from slight fluctuations your hand may have given it). By stopping the stop watch after a number of periods (and then dividing to find the actual period) you will be reducing the uncertainty in your measurements.
Another thing you might want to consider----- think about what force is making the pendulum move? Will it move as fast on the moon?
Basic outline of an experiment might be:
Take several measurements keeping the mass and angle of release constant, but changing the string length each trial.
Take several measurements keeping the string length and angle of release constant but changing the mass each trial.
Take several measurements keeping the string length and mass constant, but changing the angle of release each time.
Analysis:
What is the effect of changing these things? (Does the string length change the period? Does the angle of release change the period? Does the mass of the bob change the period?)
See attached file for a basic set up
Hope this helps
