What Forces Affect the Speed of a Ball in Circular Motion?
  • Thread starter Thread starter cstryker02
    Rotational Stuck
The discussion centers on calculating the speed of a 500 g ball swinging in a vertical circle with a 1.5 m string, where the tension at the bottom is 15 N. Participants emphasize the importance of drawing a free body diagram (FBD) to analyze the forces acting on the ball, including tension and gravitational force. The tension provides the necessary centripetal force for circular motion, while the gravitational force acts downward. Understanding pseudo-forces in circular motion, such as those felt on amusement park rides, is also highlighted as relevant to the problem. The conversation encourages a systematic approach to solving for the ball's speed using the known forces.
cstryker02
A 500 g ball swings in a vertical circle at the end of a 1.5-m-long string. When the ball is at the bottom of the circle, the tension in the string is 15 N.
What is the speed of the ball at that point?
what have you done so far? did you draw a fbd with the ball at the bottom of the circle? Did you sum the forces acting on the ball at that point? I'd say start there and see if you get an answer.
Good luck.
yea i have done the FDB but I am totally lost on the equations for the problem, i don't know how to find the speed with the "knowns" that i have been given.
Well, you have 15N acting toward the center of the circular path and 4.905N acting down. Do you know of any pseudo-forces associated with circular motion? Do you know what force keeps a person stuck to the walls of one of those spinning amusement park rides, or the force you feel when a car goes around a corner?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
