What Frequency Causes a Rock to Lift Off a Vibrating Platform?
To determine the frequency at which a rock begins to lift off a vibrating platform, the acceleration due to the platform's oscillation must be calculated using the equation ax(t) = -w^2 * Asin(wt). The key is to find the frequency that results in zero reaction force, indicating the rock has lost contact with the surface. The problem is likened to rollercoaster dynamics, but the challenge lies in the limited information provided, specifically only the amplitude of 10.4 cm. Further clarification on the relationship between acceleration, frequency, and the conditions for losing contact is needed to solve the problem effectively.
aubailey
A vibration platform oscillates up and down with an amplitude of 10.4 cm at a controlled variable frequency. Suppose a small rock of unknown mass is placed on the platform. At what frequency will the rock just begin to leave the surface so that it starts to clatter?
I know I need to find the acceleration with the given amplitude but i still have two variables, omega and time in order to find that. Can anyone point me in the right direction?
welcome to pf!
hi aubailey! welcome to pf! :wink:
what is your basic equation, the one that determines whether the rock loses contact (ie the reaction force is zero)? :smile:
Yes, how do I find the frequency that will cause the rock to be lifted a little?
i suppose it is similar to a rollercoaster problem but I am kind of stuck because I am only given the amplitude.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
