What Is the Bird's Speed After Swallowing the Insect?
  • Thread starter Thread starter jeeves_17
    Collision Velocity
The discussion revolves around calculating the speed of a bird after it swallows an insect, using conservation of momentum principles. The initial momentum of the bird and insect is calculated, with the bird weighing 0.3 kg and flying at 6.0 m/s, while the insect weighs 0.01 kg and approaches at 30 m/s. After applying the conservation of momentum formula, the final speed of the bird post-swipe is determined to be approximately 4.84 m/s in the direction the bird was originally flying. The calculations emphasize the importance of considering the direction of velocities as vectors in the momentum equations. Ultimately, the result highlights that the bird's speed decreases due to the mass of the insect it consumes.
jeeves_17
A 300 g bird flying along at 6.0 m/s sees a 10 g insect heading straight toward it with a speed of 30m/s. The bird opens its mouth wide and enjoys a nice lunch. What is the bird’s speed immediately after swallowing?
Relevant equations
Jx = m(Vx)f - m(Vx)i
Jy = m(Vy)f - m(Vy)i
Given
m(b) = 0.3 kg
v(b) = 6.0 m/s
m(i) = 0.01 kg
v(i) = 30 m/s
The attempt at a solution
Jx = (0.01)(30) - (0.3)(6.0)
= 0.12kg.m/s
0.12kg.m/s * 1/0.3kg = 0.4 m/s
.3 * 6 - .01 * 30 = (.3 + .01) * v
p1 + p2 = p1' + p2'
forget the components in this problem. the objects are traveling in a linear path, so a negative value and a positive value denote the direction. You can assign what each equal, though, just as long as you keep it consistent throughout the problem.
P1 = m1*v1
= (0.3)(6.0)
= 1.8
P2= m2*v2
= (0.01)(30)
=0.3
P1 +P2 = P3
1.8 +0.3 = P3
P3 = 2.1
P3 = m3v3
v3 = p3/m3
= 2.1/0.31
= 6.7741935
= 6.77 m/s?
jeeves_17 said:
P1 = m1*v1
= (0.3)(6.0)
= 1.8
P2= m2*v2
= (0.01)(30)
=0.3
P1 +P2 = P3
1.8 +0.3 = P3
P3 = 2.1
P3 = m3v3
v3 = p3/m3
= 2.1/0.31
= 6.7741935
= 6.77 m/s?
No. p1 and p2 are vectors and in this problem they point exactly opposite of each other
Think about it this way: this interaction happens ONLY on the x axis, so only use the x axis.p1 = .3 * 6 * cos(0)
p1 = .3 * 6 * 1
p1 = 1.8
p2 = .01 * 30 * cos(180)
p2 = .01 * 30 * -1
p2 = NEGATIVE .3
p1 + p2 = p1' + p2'
1.8 + -.3 = (.01 + .3) * v(the v after the eating happens)
if v is negative, then the answer will be at 180. if positive, 0. (remember, only because i defined 0 degrees as positive velocity and 180 degrees as negative velocity)
The answer is 4.84 m/s, 0 degrees or "in the direction the bird was flying"The problem doesn't define a perspective, so you could say the bird was flying from right to left and all that would happen is the answer will be 180 degrees instead of 0. I would just include the degrees and the words to explain your perspective. Just think about it. You could watch this collision from any perspective. The result won't change, only the way to express it.
just another way to do this is:
m1*(vf)1 + m2*(vf)2 = m1*(vi)1 + m2*(vi)2
because the bird swallows the insect (vf)1 and (vf)2 are going to be the same
(m1 + m2)*vf = m1*(vi)1 + m2*(vi)2
then solve for vf
vf= m1*(vi)1 + m2*(vi)2 divided by (m1 + m2)
to make things clear let's say the bird is flying in the positive direction, and since the insect is flying is the opposite direction of the bird making its velocity negative
sooo..
vf = (0.03kg * 6.0m/s) + (0.01kg * -30.0m/s) divided by (0.31kg)
vf= 4.8m/s
