What is the complete derivation of the nonhomogeneous fluid flow rate equation?
The discussion focuses on the derivation of the nonhomogeneous fluid flow rate equation as presented in Devendra K. Chaturvedi's book. Participants seek clarification on the integration steps leading to the general solution, specifically the completion of the equation involving the natural logarithm. The equation presented shows the relationship between concentration over time, factoring in flow rate and volume. A key point is the agreement that the logarithmic expression simplifies to match the right side of the equation. The conversation emphasizes the importance of completing the derivation for clarity and accuracy.
fahadismath
does anyone know the derivation of the general solution of the nonhomogeneous equation shown in the image (book name: Devendra K. Chaturvedi - Modeling and Simulation of Systems Using MATLAB and Simulink -CRC Press (2010))
This is basic calculus.
\begin{split}<br /> \frac{dC}{dt} &amp;= \frac{F}{V}(C_0 - C) \\<br /> \int \frac{1}{C_0 - C}\frac{dC}{dt} \,dt &amp;= \int \frac{F}{V}\,dt \\<br /> \int \frac1{C-C_0}\,dC &amp;= \ln |k| - \frac{F}{V}t \\<br /> \ln |C - C_0| &amp;= \\<br /> C(t) &amp;= C_0 + ke^{-Ft/V}.\end{split} (We can drop the absolute value signs since C - C_0 and k must have the same sign.)
in your derivation you didn't complete this step ln|C-Co|= ? KINDLY write the complete equation
It equals the same as the right side of the line above it: ##\ln |k| - \frac{F}{V}t##.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
