What Is the Correct Charge to Use for Calculating Electric Flux in a Torus?
The discussion revolves around calculating the net electric flux through a torus with given charges of -6 nC and +60 nC. The formula for electric flux is provided as Electric flux = Qin/E, where Qin is the charge enclosed and E0 is the permittivity of free space. A participant initially calculated the electric flux using an incorrect value for E0, leading to an incorrect result. There is confusion regarding which charge should be considered as the enclosed charge for the calculation. Clarification is sought on whether the +60 nC charge is contained within the torus for accurate flux determination.
jincy34
What is the net electric flux through the the torus if a=-6 nC and b=60 nC ?
Electric flux=Qin/E
I solved with Qin being 6*10^-9 C as it is the charge inside and E0=8.85*10^-12. I got 678 for electric flux. But it is wrong.
\epsilon_0 = 8.85*10^{-12} not 8.85*10^{-9}.
This may be your problem. If it is not, show your work and we may be able to give you more in depth help.
I put the right value for E0. But, I am not sure if the charge I am using is right or not. Is the charge inside 60nC, 6nC or net charge?
Is the +60nC charge contained inside the surface of the solenoid?
