What is the direction of the change in velocity of the ball?
The discussion centers on calculating the direction of the change in velocity of a softball with a mass of 0.15 kg, initially traveling at 16 m/s. After being struck, the ball moves at a 45° angle to its original direction with the same speed. The correct approach involves treating velocity as a vector and using the formula Δv = v + (-v0) to determine the change in velocity. The final direction of the change in velocity is towards the new trajectory of the ball, which is at a 45° angle from the original path.
  • Understanding of vector addition in physics
  • Familiarity with basic kinematics
  • Knowledge of trigonometric functions
  • Ability to decompose vectors into components
  • Study vector addition and subtraction in physics
  • Learn about kinematic equations and their applications
  • Explore the concept of momentum and its conservation
  • Practice problems involving angles and velocity changes
Students studying physics, particularly those focusing on mechanics and kinematics, as well as educators seeking to clarify concepts related to vector velocity changes.
rachael
9 A softball of mass 0.15 kg traveling at a speed of
16 m s–1 is struck so that it moves away from the bat at
an angle of 45° to its original direction and with the
same speed.
a What is the direction of the change in velocity of the
ball?
how do u work this question out ?
the book told me to use mgsinX/m
when i tried to do it it does not give the correct answer
thank you
The direction of the change in velocity must be in the direction of the final velocity of the ball since the ball changes its direction to opposite side. Can you clear the all questions?
same speed.
ball?
thank you
To find the change in velocity, remember that velocity is a vector. So:
[tex]v_0+\Delta v = v[/tex] by definition
[tex]\Delta v = v+(-v_0)[/tex] where -v0 is a vector of length v0 in the opposite direction to the vector v0.
So assume v0 is pointing along the +x axis. Then v is pointing at 45 degrees above the -x axis. [tex]\Delta v[/tex] is a vector pointing from the head of v0 to the head of v. Using components you should be able to find the components of the change in velocity.
-Dan
  • · Replies 19 ·
