What is the final volume of container B?
The discussion revolves around calculating the final volume of container B, which has a movable piston, after heating it with a 25 W heater for 15 seconds. Participants are trying to apply the ideal gas law and energy equations, but there is confusion regarding the correct approach, particularly in how to account for work done by the piston and the energy transferred from the heater. Initial pressures and energy calculations are discussed, but some participants express uncertainty about the equations used and the significance of container A in the context of the problem. The conversation emphasizes the need to correctly interpret the work-energy relationship and apply the right formulas to find the final volume of container B. The final volume calculation requires careful consideration of the energy input and the work done by the piston.
skinard360
Two 800\; cm^3 containers hold identical amounts of a monatomic gas at 20^\circ C. Container A is rigid. Container B has a 100\; cm^2 piston with a mass of 10 kg that can slide up and down vertically without friction. Both containers are placed on identical heaters and heated for equal amounts of time.
Suppose the heaters have 25 W of power and are turned on for 15 s. What is the final volume of container B?
I found the initial pressures of both container B, I then plugged that into the initial pV=nRT to find n, then plugged that into
E=[nc(constant pressure)deltaT] using 25x15=375 J as the value for E. This determined delta T, I then plugged that (with T = delta T + 293) into the final pV=nRT to get V. This seems like it's probably too complicated, and I didn't get the right answer...can someone please help??
I'm somewhat confused with your notation 100\; and I don't know what the significance of container A is.
that should just be 100 cm squared. I'm not sure what the significance is of container A is either...it may have to do with question (a) which asked which container would have the higher final temp. Do you think container A should have some part in the answer?
ahh, ok, A seems to be only for part a).
I'll poke at b) and give you hints
to start you off, they give you power (in watts) and the length of time that power is exposed to the system. Power has energy of units over time and time has units of time. Using those two quantities, you should be able to calculate the energy put into the system by the heaters.
furthermore, Boltzmann's constant and temperature are equatable to energy.
I think... that container A and B share the energy from the heater.
that would be the thermal energy, right? 375 J...did I use the right equation above with E=ncdeltaT with c=20.8 ? or should it be another equation, since that equation is assuming that the pressure in the system stays constant
Also, for constant pressure, W = P(del V)
(work equals pressure times the change in volume)
which can be represented as W = P(V2 - V1)
What is c? That looks an awful lot like part of the phase change equation which shouldn't be used here, that's for when a material changes form (from liquid to gas and such)
I tried another equation to get the final temp...thermal energy = 375 = (3/2)NkBT...then plugged it into pv=nRT but this didn't work either
For the work equation above, does work = 375? I feel like I'm getting more confused the further I go
I'm not quite sure about this. Let me play with it more and get back to it
This may be a good point too, I'm not sure. What's the answer so I know when I get it?
I'm not sure what the answer is...sorry
but I know the initial pressure is 1.097 atm
note that in B, some of the work is going to go into lifting the piston:
W=mgh
then why wouldn't W = P(V2-V1) work then? pressure stays constant if volume is allowed to change (i.e. the piston)
You just have to make sure you use the right W (that is, whether it's the full energy delivered by the heaters or only half.
Suppose the heaters have 25 W of power and are turned on for 15 s. What is the final volume of container B?I found the initial pressures of both container B, I then plugged that into the initial pV=nRT to find n, then plugged that into
How did you determine the pressure in A and/or the volume in B?
AM
