What is the implicit differentiation of the van der Waals equation?
The discussion revolves around the implicit differentiation of the van der Waals equation, specifically focusing on finding the derivative of pressure (P) with respect to temperature (T). The original poster expresses confusion regarding the differentiation process due to the presence of multiple variables and the instructions given by their professor.
  • Participants discuss the steps involved in implicit differentiation and the need to differentiate both sides of the equation. There are questions about the clarity of the instructions and the objective of checking the derivative through different methods. Some participants suggest that the original poster clarify whether they are differentiating with respect to temperature (T) or time (t).
The discussion is ongoing, with participants providing insights into the differentiation process and questioning the original poster's understanding of the problem. Some guidance has been offered regarding the differentiation techniques, but there is no explicit consensus on the correct approach or interpretation of the problem.
There is mention of confusion regarding the variables involved and the need to specify which quantities are held constant during differentiation. The original poster's instructions from their professor are also under scrutiny, as participants seek to clarify the intended meaning behind the differentiation task.
ABearon
Member warned that homework problems should be posted in a homework forum section
Summary:: van der waals
I have a pretty good understanding of implicit differentiation. However I'm stuck on a homework problem and could use some help.
[P + (an^2)/V^2][V - nb] = nRT a,n,b,R are constants
My professor wants me to take the implicit differentiation of P wrt T. She then says solve for P then take the derivative to check your answer. I understand the chain rule and product rule. Could someone show the steps to solving using these rules. I'm used to having 3 intermediate variables as functions of t and seeing it this way is confusing me.
Do \frac{d}{dT} on both sides.
I got {nR - [P+(an^2)/V^2][dV/dT]}/(V-nb) - d/dt[(an^2)/V^2]
Using Latex might help:
https://www.physicsforums.com/help/latexhelp/
Although, to be honest, I have no idea what you are trying to do. How does differentiating an equation check the answer? Check it in what way?
I believe what is meant here is to do these operations:
  1. Find the derivative dP/dT using implicit differentiation.
  2. Solve for P, and then differentiate normally to find dP/dT.
Both techniques should result in the same derivative.
@ABearon, you have posted several threads in sections other than the homework sections. In the future, please post homework questions in one of the forum sections under Homework & Coursework.
I guess the objective is to find ##\frac{dP}{dT}##. That seems like an obvious thing to say in the OP.
From post #1:
A better way to say this probably would be "Find dP/dT using implicit differentiation."
Wait. Are you differentiating with respect to temperature (T) or time (t)? Don't keep switching back and forth between them, choose one symbol. it's very confusing.
Adjusting the formatting to what I think that says based on the brackets, I think that line says this:
$$\frac{nR - \frac {P + an^2} {V^2} \frac {dV}{dT}}{V - nb} - \frac {d}{d?} \frac {an^2}{V^2}$$
Since V is apparently treated as a function of t or T, whatever you're differentiating with respect to, then you can apply the Chain Rule to that last term.
I'm not saying whether this is a correct differentiation or not, just what I think you wrote. Actually I can see one thing clearly wrong with it at a glance: Implicit differentiation of an equation should give you an equation.
I'm a bit puzzled by the question. In thermodynamics it's important to say which quantities are kept constant when calculating derivatives. For a gas you have three independent variables (e.g., ##n##, ##V##, and ##T##).
12K
