What is the potential difference Vad-Vac?
  • Thread starter Thread starter dwstrait
    Capacitors Switch
The discussion focuses on calculating the potential difference Vad-Vac in a circuit involving capacitors. The initial potential difference applied is Vab = +210 V. The equivalent capacitance of the series configuration is determined to be 4 x 10-6 F. The charge on the capacitors is calculated using Q = CV, resulting in a total charge of 8.4 x 10-4 C. Ultimately, the potential differences are found to be Vad = 140 V and Vac = 70 V, leading to the conclusion that Vad - Vac = 70 V.
  • Understanding of capacitor configurations (series and parallel)
  • Familiarity with capacitance calculations (C = Q/V)
  • Knowledge of equivalent capacitance formulas (1/C = 1/c1 + 1/c2 for series)
  • Basic principles of electric potential difference
  • Study the principles of capacitor charging and discharging
  • Learn about complex capacitor networks and their analysis
  • Explore the impact of dielectric materials on capacitance
  • Investigate the applications of capacitors in AC circuits
Students in electrical engineering, physics enthusiasts, and anyone seeking to deepen their understanding of capacitor behavior in circuits.
dwstrait
1. The problem statement
The capacitors in the figure are initially uncharged and are connected, as in the diagram, with switch S open. The applied potential difference is Vab = + 210 V.
What is the potential difference Vcd?
(series) 1/C = 1/c1 + 1/c2 + ...
(parallel) C = c1 + c2 + ...
C=Q/V
Trying to find Vcd:
I first found the equivalent capacitance of the series, which is 4*10-6 F. I calculated the charge on the capacitors using Q = CV, which was 8.4*10-4. Then, I tried to find Vad and Vac by using V=Q/C. I don't think this is the right way to do this problem though.
That looks like the way to do it as far as you went.
Ah, I figured it out. The upper and lower series each have half the value of the charge that I calculated. Then using V=QC, Vad=140V and Vac=70V, so Vad-Vac=70V.
14K
13K
