What Is the Probability of Finding the Perturbed Oscillator in Its Ground State?
Demon117
I showed earlier this semester that in the presence of a "constant force", F_{o}, i.e. V=-Fx, that the eigenvalues for the Harmonic oscillator are shifted by
\frac{F^{2}}{2m\omega^{2}}
from the "unperturbed" case. It was also discussed that x\rightarrow x-\frac{F}{m\omega^{2}}.
An oscillator is initially in its ground state (n=0). At t=0, a perturbation V is suddenly applied. What is the probability of finding the system in its (new) ground state for t>0, i.e. find |a_{o}|^{2}.
For this |a_{n}|^{2}=|\int \Phi^{*}_{n}(x)\Psi_{o}(x)dx|^{2} over all space.
For t>0, the state of the system is \Psi(x,t)=\sum a_{n}exp(-i(\frac{E_{n}}{\hbar})t)\Phi_{n}(x). Here \Phi_{n}(x) is an eigenvector of H. And the coefficients a_{n} are obtained by expanding \Psi_{o}(x), the ground state of H_{o}, in terms of \Phi_{n}(x).
I also know that the basis states \Phi_{n}(x) as well as \Psi_{o}(x) are Hermite polynomials.
With that in mind my assumption would simply be to integrate the following:
|a_{o}|^{2}=|\int \Phi_{o}(x) \Psi_{o}(x) dx|^{2} =|\int 1*1 dx|^{2}
If I integrate this over all space I end up with a probability that goes to infinity. . . .Maybe I am missing something as far as Hermite polynomials go. . . or maybe I have the wrong idea about this problem. Any suggestions would be helpful.
Hi matumich, sorry I'm not sure if I can help but if you could so kindly explain to me where you got the relavant equation for |a_n|^2 and for psi(x,t) I would greatly appreciate it. Also, could you explain to me why the last line is equal to |integral 1*1 dx|^2?
Well I made several mistakes. The equation |a_{n}|^{2}=|∫Φ^{∗}_{n}(x)Ψ_{o}(x)dx|^{2} was given in class. The coefficients a_{n} are obtained by expanding Ψ_{o}(x), the ground state of H_{o}, in terms of Φ_{n}(x). From this it follows that the probability of finding the system in some state (t>0) is given by that integral.
This was just purely as mistake and since the eigenfunctions Φ_{n}(x) correspond to the state once the perturbation is applied they can be expanded in terms of their basis elements, which in this case are the Hermite polynomials. Similarly, the unperturbed wave function Ψ_{o}(x) can be expressed in terms of the Hermite polynomials. Therefore we have:
Φ_{n}(x) = C exp(-\frac{1}{2}\alpha^{2}(x-\frac{F}{m \omega^{2})^{2})H_{n}(x)
Ψ_{o}(x) = Cexp(-\frac{1}{2}\alpha^{2} x^{2})H_{o}(x) = exp(-\frac{1}{2}\alpha^{2} x^{2})
The probability would be along the lines of
|a_{o}|^{2}=|∫C exp(-\frac{1}{2}\alpha^{2}(x-\frac{F}{m \omega^{2})^{2})exp(-\frac{1}{2}\alpha^{2} x^{2})dx|^{2}
After normalizing both wave functions you can integrate this and find the appropriate probability of finding the system in the ground state for t>0.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
