What is the solution to part a of Density physics homework?
The discussion centers around a physics homework question related to density. The original poster shares their solution for part a and seeks reassurance on its accuracy. Respondents confirm that the solution appears correct, including the calculated density for copper. The conversation highlights the importance of peer feedback in understanding complex physics problems. Overall, the solution is validated by others in the thread.
Looks correct to me. Even the correct density for copper.
Thanks for the quick response.^^
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
