Does pressure change along a vertical path with pressurized fluid at 70psi?
  • Thread starter Thread starter Kaly
    Pressure Value
Pressure in a closed-loop system with pressurized fluid will change with vertical height due to the effects of gravity, even if the fluid is initially pumped at 70 psi. As the fluid rises or falls, the pressure at any point in the system will be influenced by the height of the fluid column above it. The pressure increases with depth, similar to how underwater pressure works. The configuration of the system, including the pump and tank placement, plays a significant role in determining the pressure changes. Overall, vertical movement of the fluid will result in pressure variations, regardless of whether the system is closed or open.
Kaly
Hello, I am willing to know if the value of pressurized fluid along a rectangular path placed normal to ground (let's say 2 stories high) would show any change in pressure along the lines normal to ground. I am not worried where fluid would move horizontal to ground but what would happen when it rises or falls? would pressure change? or remain same if it is pumped at 70psi pressure let's say.
Welcome to the PF.
Could you please post a sketch of the configuration of the tank and pump? Fluid pressure increases as you go deeper in the vertical direction, just as you experience a greater pressure as you dive deeper underwater. Is that what you are asking about?
Thank you for the comment. Path is rectangular in shape. but it is closed loop so not really exposed to atmosphere. The pump sits on ground. It first pushes liquid 2 stories high. At the top fluid then it follows horizontal path then the fluid falls by 2 story height and again it flows though horizontal path, reaches the pump and is pumped again 2 story high. I am not sure if not being exposed to atmosphere keeps the value of pressure same through out the path? or no matter the system being closed or open the vertical height of water column would add to pressure at ground level.
How much formal Fluid Mechanics training have you had? If you had a course, what was covered?
Kaly, Is this a real system or just a problem someone has given to you?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
