What Is the Wavelength of the Signal Based on Goniometer Measurements?
The discussion revolves around determining the wavelength of a signal based on measurements taken with a goniometer. The problem involves moving a receiver through a series of intensity minima and maxima, with specific distances provided.
  • Participants discuss the calculation of wavelength based on the distances between intensity maxima and minima. There is confusion regarding the number of maxima and minima encountered during the movement of the receiver.
Participants are actively questioning the assumptions made in the initial calculations. Guidance has been offered regarding the relationship between minima and maxima, suggesting that there are multiple wavelengths involved in the measurements.
There is a noted confusion regarding the interpretation of the problem statement, particularly in relation to the number of maxima and minima and how they relate to the wavelength calculation.
Mnemonic
Initially your receiver is positioned at a distance of 8.4 cm from the goniometer and recording a maximum intensity. You move it through 10 minimums in the intensity and then stop at the next maximum intensity. The receiver is now a distance of 27.3 cm from the goniometer.
What is the wavelength of the signal you have measured?
ƛ/2=Distance between two maximums
ƛ=2(27.3-8.4)cm
=37.8cm
It's that simple right?
I keep getting the wrong answer with this. What am I missing?
ƛ=2(27.3-8.4)cm
=37.8cm
You are not taking into account that it was moved through many minima and maxima. You have calculated as though it was moved to the very next maximum.
The wording in the question confused me. So you are saying that between each of the 10 minimums there was a maximum as well?
That's the usual arrangement.
SO there are 5 complete wavelengths.
Therefore ƛ=(27.3-8.4)/5 cm
That looks better.
  • · Replies 19 ·
