What is the Wien bridge frequency proof and how do you solve it?
The discussion focuses on solving the Wien bridge frequency proof, specifically how to determine the frequency when the bridge is balanced. The key equation derived is based on the impedances of the circuit components, leading to a complex equation that requires equating real and imaginary parts. Participants share their attempts at calculating the impedances, with one user successfully simplifying their approach by focusing on the real parts of the equation. Ultimately, the solution involves balancing the equation to find the frequency using the relationship between the resistances and capacitances in the circuit. The thread concludes with a resolution to the problem through careful manipulation of the impedance values.
birdgirl
[SOLVED] Wien Bridge Frequency Proof
The ac bridge circuit shown is called a Wien bridge (also Wein bridge).
Show that when the bridge is balanced, frequency is found by the Eqn attached.
w=2*pi*f
Using the number from each branch as a guide, the general solution to AC bridges is Z4 = (Z3/Z1)*Z2
I keep trying to solve for impedences to plug into the second equation provided, but my j values do not cancel and the equation left is rather messy (R2R4C2C4*w^2 +jw(RzR4C2 -R2C2 -R4C4) +1 = 0.
For my impedence values I have been using
Z1 = R1
Z2 = R2 -j/wC2
Z3 = R3
Z4 = (R4/jwC4)/(R4 +jwC4)
Any help with this would be greatly appreciated.
I think Z_4 = \frac {-jR_4} {\omega C_4 (R_4 - \frac{j}{\omega C_4})}
Both the real and the imaginary parts of Z4 = (Z3/Z1)*Z2 must be 0
Actually, I think our Z4 values are the same, since -j = 1/j. But thank you! I managed to figure it out after you got me thinking about real and imaginary parts.
It's fairly simple, actually: I just had to equate the real parts from my equation so that R2R4C2C4*w^2 + 1 = 0 (and then I took absolute value).
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
