What weight is needed to keep a relief valve closed at 10 psi on a large vessel?
  • Thread starter Thread starter steves1080
    Weight
To keep a relief valve closed at 10 psi on a large vessel, a pressure of 9.5 psi is required to counteract the valve's lift pressure of 0.5 psi. The calculation involves using the formula F = P*A, which results in a force of approximately 1075 lbs needed to maintain closure. The large area of the valve, approximately 113 square inches, significantly contributes to the force calculation. Despite initial doubts about needing such a high weight, the calculations confirm that this weight is necessary due to the pressure acting on the valve's area. Understanding these principles is crucial for safely managing pressure in large vessels.
steves1080
I have a large vessel that I would like to add a 10 psi purge to. There is a relief valve on it that is set to lift at 0.5 psi (essentially a flat circular plate 1 ft in diameter), so I am simply looking to keep this closed so that I can build up 10 psi inside the tank (don't worry, the tnak is rated for that pressure). Trying to figure out how much weight I'd need to do this, but doing the calc gives me a circular area of ~113 square inches, which would then provide a force of (113)(10) = 1130 lbf. I highly doubt I need 1130 pounds to hold this closed, so I must be missing something obvious here. Any insight would be greatly appreciated. Thanks
Hi,
You need a pressure of 9.5psi to keep the valve shut (difference in pressure). Using F = P*A and W = F/g I get a weight of around 1075lbs. Seems a lot but it's quite a straight forward calculation - you have a large area that the pressure is acting on.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
